Aerostar Ford Aerostar
IAC purpose?
Old Jul 22, 2007 | 06:38 PM
DOUG5G's Avatar
DOUG5G
IAC purpose?
What is the purpose of this little thing? I am having cold idle problems and I think it is the problem. I took it off and cleaned it without any success like I normally see. This time I played a little more and I plugged 12VDC into it to see if it worked. Yes I saw the plunger move back and forth. But what looks a plug that would go in between the two sides doesn't look like it is closing. I can blow into each hole and air comes out of the other. I also got the same results with it energized. Should I be able to blow air between the two? BTW yes I also get some air flow out the little vent in the side.
Couple of patially useless facts.
1. I measured accross the two terminals and it measured 10 Ohms
2. When the engine is cold I measured the red wire as getting 14VDC.
Old Jul 22, 2007 | 07:24 PM
96_4wdr's Avatar
96_4wdr
I.dle A.ir C.ontrol
http://fordfuelinjection.com/?p=39
Ford says type with small black plastic filter cap not cleanable, replace only
they do become permanently plugged or jammed by crankcase products and dirt...
some on the forum have success...try soaking air end in TB cleaner
acuator voltage is correct for yours
change your PCV valve if plugged, leaking or older than 50k, major cause of IAC failure
Old Jul 22, 2007 | 07:55 PM
DOUG5G's Avatar
DOUG5G
Wow that page explains it all. Since my plunger is never closing all of the way mine is bad!
Thanks
Doug
Old Jul 22, 2007 | 09:49 PM
96_4wdr's Avatar
96_4wdr
reread your original post
cold idle only problems are usually a failed ECT sensor engine coolant temp sensor the 2 wire one not the one wire gauge sensor
check wire and connector, they often are damaged or get pulled off
replace only, not serviceable
Old Jul 23, 2007 | 11:12 AM
DOUG5G's Avatar
DOUG5G
That makes sense. I just had my water pump die and the engine overheated. Plus the bolts were frozen and I had to get them machined out $$$$$. The single wire has to be good because i do see the guage move. Where is the ECT sensor located?
thanks
Doug
Old Jul 23, 2007 | 04:10 PM
DOUG5G's Avatar
DOUG5G
I can find on the Ford Cd that it says this about the ECT.
The Engine Coolant Temperature (ECT) Sensor (Figure 7) detects the temperature of engine coolant and supplies the information to the Powertrain Control Module (PCM).
The ECT sensor is threaded into the heater outlet fitting or cooling passage on the engine. For engine control applications, the ECT signal is used to modify ignition timing, EGR flow and air to fuel ratio as a function of engine coolant temperature. On electronic instrument cluster applications, an additional ECT is used as a coolant temperature indicator.
It sure doesn't help find the darn thing.
Old Jul 23, 2007 | 04:26 PM
Mormakil's Avatar
Mormakil
Well, it's at the front, "top" of the engine, almost dead center...move your hoses aside and look for the thermostat housing; it should be near there. Follow the wires that are headed that way. Above the water pump. Hope that makes sense.
Old Jul 23, 2007 | 04:42 PM
DOUG5G's Avatar
DOUG5G
I spoke to soon. I found it!!! How do I test it?
Thanks
Doug
Old Jul 23, 2007 | 07:49 PM
aerocolorado's Avatar
aerocolorado
Thanks
Doug
Not by using the Chilton's guide. The test procedure (dunking in boiling water) is for the old style ECT. These newer ones are a thermistor design. As the water warms the sensor, the resistance changes and the engine computer reads the change and adjusts the timing/injector output accordingly.
To answer your question, take the ECT sensor out and let it stay at room temp (or lower). Connect an ohm meter across the two terminals. You can actually just pick it up at this point and hold it tightly in your hand. If it is working, you will see the resistance start going down. (There are charts to match resistance and temperatures to see if the ECT is within specs.)
Old Jul 23, 2007 | 09:29 PM
Aeroman59's Avatar
Aeroman59
If the ECT is telling the PCM that the engine is warm all the time, then you could have cold start problems, due to lean mixture at start up. You could inject some Propane gas into the air cleaner intake & see if it improves the cold idle. I'm thinking the ECT is cheap enough to replace. What happens when you pull the wire off the IAC ?
What does the engine idle like when hot?
ATB Aeroman.
Old Jul 26, 2007 | 07:47 AM
DOUG5G's Avatar
DOUG5G
I checked the resistance hot and it read 2.2K ohms and cold it read 9.5K Ohms . Normal????? I removed it while it was cold and started her up and she idled even worse then when connected. I didn't try it removed while hot but normally she idles pretty good while hot. When I say she idle poorle when cold she idles bad enough that I can see the Votage guage jump around. Hot it is steady.
Thanks
Doug
Old Jul 26, 2007 | 09:14 AM
Aeroman59's Avatar
Aeroman59
I checked the resistance hot and it read 2.2K ohms and cold it read 9.5K Ohms . Normal????? I removed it while it was cold and started her up and she idled even worse then when connected. I didn't try it removed while hot but normally she idles pretty good while hot. When I say she idle poorle when cold she idles bad enough that I can see the Votage guage jump around. Hot it is steady. Thanks
Doug
From what you describe, it certainly sounds like a cold engine mixture problem. The fact that the engine idles fine while hot means that the actual merchanical combustion system on your engine is O.K. ( pistons, valves, plugs, etc).
Can you buy a new sensor & compare readings on your multi-meter? if good take it back! You could do the same with the IAC, as long as you dont fit it to the engine they are usually returnable. If the resistance changed from 2.2 k up to 9.5k on the ECT it sounds like it's doing the job.
Old Jul 26, 2007 | 01:17 PM
96_4wdr's Avatar
96_4wdr
ECT way too low at cold temps.
should be 25K ohms at 85d F.
at 9.5K ohms, it's telling the PCM that your engine is 140d F, almost warmed up closed loop condition for the hwy.
will cause a lean fuel condition on cold idle=rough idle
overheated engine often kills ECT and knock sensors
replace the radiator cap also, often toasted in engine overheat
check the hoses, they get stressed from overheat and can blow at anytime
Old Jul 26, 2007 | 02:07 PM
DOUG5G's Avatar
DOUG5G
Should I put any type of sealant or antiseize around the new ECT?
Old Jul 26, 2007 | 05:53 PM
Aeroman59's Avatar
Aeroman59
Thumbs up
From what 96 4wdr says, that ECT (thermistor) is definately frazzled ! The cold open loop condition generally lasts about 4 mins where the PCM sends enriched mixture to the engine, does that sound about right?
Wrap the threads in PTFE tape or Teflon tape, that way if you ever have to replace it again , it will be removable. Antisieze is not really a thread sealer.
2-3 complete turns of tape should do it.
Aeroman.
