Aerostar Ford Aerostar
IAC purpose?
Old Jul 27, 2007 | 09:15 AM
Bear River's Avatar
Bear River
Former ******
Actually, not not wrap the sensor in teflon tape. The sensor uses engine ground for an accurate reading. Teflon interfers with the electrical ground. The threads on the sensor are tapered, so they get tighter the farther they thread in. They will seal themselves. Or use copper based gasket maker on the threads.
Old Jul 27, 2007 | 01:42 PM
xlt4wd90's Avatar
xlt4wd90
Tapered pipe threads will not always seal themselves. In fact, you will find that almost none of them will, which is why you need thread sealants on all tapered thread fittings. Thread sealants in general are for filling the gaps between the engaging threads through which fluid will leak. That also means that there will always be parts of the threads of the two parts touching, as long as you torque it sufficiently. I've used Teflon tape on plenty of sensors with no problems. If you have doubts, check the continuity between the base of the sensor that threads into the engine and the engine.
Old Jul 27, 2007 | 02:01 PM
96_4wdr's Avatar
96_4wdr
tape and seal away
the ECT and other sensors do NOT use the engine block/chassis as signal return /gnd to the PCM
the ECT has 2 leads, PCM input and SIG RTN which is the PCM ground reference.
if the PCM system tried to use the block/chassis, there would be interfering ground loops and voltage differences along with RFI causing problems with correct PCM operation....
the SIG RTN is the PCM's separate ground reference system
internal sensor leads do sometimes short out to the chassis mounting device...can cause real troubleshooting headaches especially if SIG RTN shorts to block/chassis
Old Jul 28, 2007 | 07:53 PM
DOUG5G's Avatar
DOUG5G
She now idles perfectly!!! I replaced the ECT and it didn't make any change. The connections were really dirty on the old one and once I cleaned them off it read 29K Ohms at 72 degrees. The new one read 30K ohms. So....I ended up replacing the IAC and the PCV valve at the same time. The only bad thing is the old IAC had the connector coming off at an angle and the new one came out the back. The wires are just barely long enough to reach.
chewedtoothpick
Apr 17, 2014 04:47 PM
Cruickie
19
May 19, 2010 07:28 PM
tdpower
18
Feb 22, 2009 10:00 AM
m000996
Electrical Systems/Wiring
Mar 23, 2007 07:37 PM
