Gearing Question
Jul 22, 2007 | 05:38 PM
Gearing Question
I own a 94 F-150 4x4. It was originally a 300, 5 speed, with 3.08 gears. I swpped out the engine for a rebuilt 351w and upsized to 33" tires. I installed a 6" suspension lift and swapped in 3.55 geared front and rear ends. What gears would be the same as 3.55 with stock tires?
Jul 22, 2007 | 06:37 PM
what was the stock size tires? that makes a huge difference
Assuming it had 235/75-R15 originally approx a 29" tire then to get the same gear ratio with 33s as those with 3.55s closest would be a 4.10 ratio
Jul 22, 2007 | 06:45 PM
IF the stock tire size was about 29"(235/75R15), then 4.10s would bring you back to 3.55 plus alittle more(closer to about 3.62).
Jul 22, 2007 | 09:50 PM
I was thinkin of going with 4.10 so that works out good. Thanks.
Jul 24, 2007 | 06:48 PM
You'll only be turning 27 rpms higher with the 33s and 4.10s, than you would with the 29s and 3.55s @ 55mph with the 5 speed.
Jul 31, 2007 | 05:48 PM
What gears should I be running with 33s? And If I upgraded to 35s?
Jul 31, 2007 | 06:29 PM
You will have to change the carrier to put 4.10's in the front. Good time to upgrade to a limited slip or locker. I run a trax lock in mine.
Jul 31, 2007 | 06:49 PM
4.10s would be good for either size.
Peter A.
Feb 7, 2017 11:30 AM
jaltman1984
Mar 5, 2014 09:26 AM
1992FordF150Custom
22
Aug 5, 2013 06:11 PM
Shwan_89HD
26
Oct 1, 2012 07:27 PM
CPerry
1997 - 2003 F150
Jul 22, 2003 09:48 PM
