I'm thinking about replacing the 265/75 16 tires with 285/75 16's. My question is: Will I need to put 3.73 or 4.10 gears or will the 3.55 rear end be ok with the 33 inch tires and a 4.6 V8?
You will have to either change gears or reprogram the ECM for the tire change. If not, it will not shift right and the speedo will be off. 4.10 gears would definately help the 4.6 accelerate better.
Jimmy
ive got 33x12.5x16.5's on my 4.6L 4x4 with 3.55's and its pretty much ok. shift points leave a little to be desired but that can ba fixed with some 4.10's or a chip
