help 351m
Old Jul 22, 2007 | 05:07 PM
biketruck's Avatar
biketruck
help 351m
I started work on 1978 F-150 Ranger with 351m/400...91,000 miles. See post in 335 series engine section.
I can't seem to get truck to idle after my sons and I started working on it. Ran OK until I changed most all fluids, and cleaned carb. Idles for 5 seconds and cuts out only to restart then repeat.
ideas? suggestions?
Old Jul 22, 2007 | 11:32 PM
LxMan1's Avatar
LxMan1
Sounds like you have a vacuum leak somewhere.
Old Jul 23, 2007 | 04:02 PM
Scrapiron66's Avatar
Scrapiron66
I experienced the same situation after installing a new intake and carb. As LxMan suggests, it was a vacuum leak. Runs great now....
Old Jul 25, 2007 | 09:15 AM
biketruck's Avatar
biketruck
I tried the trick I read about here to determine if there is a vacum leak. Sealing off air to carb should make rpm increase. This only kills engine. Vacum lines look good but I am still checking in and under moter for bad ones.
Also float looks good. Wow, this is tough...any ideas?
Old Jul 25, 2007 | 11:38 AM
LxMan1's Avatar
LxMan1
Spray carb cleaner down both sides of the intake where it meets the head and see if it idles up. If so , the intake gaskets are leaking. Also spray aroung the bottom of the carb to see if you have a leak there. It will still die if you smother the carb unless you have a really big leak. You can slowly cover it and see if the idle goes up any before choking out.
Old Jul 25, 2007 | 06:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
I like to use a propane torch without a flame instead of carb cleaner. I have used many flammable substances in the past.
Old Aug 12, 2007 | 03:40 PM
clunker86's Avatar
clunker86
i had that problem before but it wasnt from cleaning the carb it was a bad carb. to keep it running you had to kep giving it gas or it would die. maybe its time to rebuild carb or new one. i had a 2bbl so i replaced the carb and intake for a 4bbl.
Johno.h
19
Sep 10, 2016 06:30 PM
tomandheneryrock.bw
Jun 20, 2016 07:59 AM
bluebaby
Jan 21, 2014 10:06 PM
10strokin
Aug 13, 2011 10:08 PM
Ken2600
Nov 15, 2004 10:31 PM
