Power steering pump question
Old Jul 25, 2007 | 09:01 AM
joe hoffman's Avatar
joe hoffman
Jim,
Had a similar problem, wound up about as cheap to replace with new.
Old Jul 28, 2007 | 04:53 PM
raerjim's Avatar
raerjim
Ok, so changing the pump was no big deal. Today I decided to take an hour out of my day and relocate the PS cooler from it's current location atop the York A/C compressor, which was useless out of any airflow, to just below the garvel pan, in fairly clean airflow. 5 hours later, I got the mounting bracket welded up, and the whole works re-plumbed. Man, 5/16 trans hose is a BEAR to "slip" over 5/16th barbed nipples. I'm still not sure I got them on far enuf. I never really noticed b4, but that whole PS assembly gets H-O-T!! I won't bore bore you with pics unless you want them.
Old Jul 28, 2007 | 05:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I had to do a replacement hose on my son's TBird SC and I agree about the hose fit over fittings. I spent an hour to get one hose onto a fitting. I was told they are made to be assembled by a machine and the tight fit eliminates the need for a clamp. Add to that the fact your hands are always slick with that nasty red fluid, it's a frustrating job.
87-XL-Squared
13
Nov 17, 2013 03:13 PM
terceslil
20
Aug 17, 2009 10:43 AM
Hummerkiller
Feb 25, 2006 05:42 PM
Hummerkiller
Texas Chapter
Feb 21, 2006 06:40 PM
