6637 air filter EASY QUESTION
Old Jul 20, 2007 | 10:24 PM
bdrummonds's Avatar
bdrummonds
I believe at Napa the part number is 46637. It was originally engineered for a cummins 5.9B motor that was used in industrial air compressors and also mobile generators, so it is intended for dusty areas. But it was also intended to be placed in a canister type intake. All that being said would I give mine up? NOPE, it does just fine under my hood. My first one went for 1 year and 38K miles before I changed it.
Old Jul 20, 2007 | 10:32 PM
FN74's Avatar
FN74
Originally Posted by tcm368
did you notice any difference after installing the filter
I did the 6637 and the straight pipe at the same time, and I can tell you that the two together made HUGE differeance in spool up of the turbo. Much quicker. Using my military vehicle diaggnostics kit, I actually measured the Vacum at the filter, and the backpressure before the muffler and noticed a max of about 1" of vacum on the OEM filter, and somewhere near 10psi prior to the OEM muffler. I have since lost the actual numbers, but those are close. One undesirable side effect of the 6637 though is you will get surge if you are towing between about 13-18psi. I did a wicked wheel and that fixed my surge. Some have to replace the turbo housing with a proted unit, or an ATS.
Old Jul 23, 2007 | 07:36 AM
tcm368's Avatar
tcm368
great info guys thank you, it looks like i got some simple mods to do this weekend
kriegerOG
Aug 6, 2017 11:51 AM
ocracokenc
Jan 14, 2017 08:11 AM
ultrasks700
May 24, 2016 11:57 AM
AJUSAcom
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 31, 2012 03:31 PM
tankkillr
6.4L Power Stroke Diesel
Dec 26, 2011 03:26 PM
