E04D Mass Conversion
Old Mar 5, 2010 | 06:56 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
The computer and main harnesses are married together on the 1994 F150 I plundered, it stretched all the way across the front of the truck to the battery. Good luck! Make sure you get the entire air intake assembly too.
Old Mar 6, 2010 | 05:48 AM
SmokeBlower's Avatar
SmokeBlower
When you say "make sure and get the entire intake assembly", what do you mean?
Just the throttle body, throttle body and upper plenum, or everything (from the throttle body to the lower intake)?
The truck I am pulling the parts from has a 302........the lower intake wont fit a 351w.
I just replaced the TPS on my 351w and I will reuse that for sure.
Old Mar 6, 2010 | 07:26 AM
BaronVonAutomatc
Air intake - all the plastic parts that connect to the TB, plus the airbox and mounting bracket. Might as well grab the windshield washer reservoir too, just in case.
Old Mar 7, 2010 | 10:09 PM
302flareside1992's Avatar
302flareside1992
i have a 1992 ford f150 e40d and when i go to convert to mass air flow can i pull the entire harness and computer out of a 1996 f150 e40d and plug it directly into my 92, after i rip the old harness out, and have everything fit and work? or will i have to have it tuned or cut the harness up any?
Old Mar 7, 2010 | 10:41 PM
Conanski's Avatar
Conanski
No.. these trucks went OBD-2 in '96 and everything is totally different and not compatable with your '92, so you need the wiring and EEC from a '94 or '95.
Old Mar 8, 2010 | 04:54 PM
302flareside1992
but with the 94 & 95 everything is plug and play no extra needed parts or splicing the harness
Old Mar 8, 2010 | 09:09 PM
BaronVonAutomatc
No, the EEC harness, main wiring harness, and fuse/relay box are all wired together on a '94.
Old Mar 8, 2010 | 09:32 PM
302flareside1992
so i would need to grab the eec harness, main harness and the fuse box and put them all on my 92
Old Mar 9, 2010 | 03:45 PM
Kemicalburns's Avatar
Kemicalburns
all you need is the entire engine/intake harness/maf harness and computer. you dont need the fuse box.
jackdanielfreeman
16
Nov 20, 2025 12:34 AM
jberylecrider
33
May 24, 2015 11:49 PM
MonroeHandyMan
Mar 17, 2015 03:19 PM
Wt91
Nov 9, 2014 11:59 PM
D-RockJD
1978 - 1996 Big Bronco
May 31, 2012 11:09 AM
