Sponsored by: Real Truck
lug nut torque?
Old Jul 20, 2007 | 03:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by jake00
the tire place told me 1150 lbs for my alloy wheels
Holy crap. Might wanna get a second opinion.
Old Oct 15, 2011 | 12:20 PM
79-f250-460's Avatar
79-f250-460
the correct torque specs for all ford trucks is if the lug nuts are 3/4 -100ftlbs 13/16-150ftlbs, these torques are the same for steel wheels or aluminum,
Old Oct 17, 2011 | 10:12 PM
horsecop's Avatar
horsecop
Nothing like loosing a back wheel going across Nebraska pulling a 30' Sundowner fully loaded w/ two horses on board, probably figured a impact gun would be tight enough and besides they were torqued before leaving the house back in Tennessee! NOT. Torque the lugs to the specs on the wheel.
Old Oct 18, 2011 | 05:46 AM
m350's Avatar
m350
I have always torqed mine to 140 ft lbs and never had a problem,,a dab of never-seize, on each stud,,,and clean the wheel center and apply a thin layer there also to prevent Alloy wheel corroding/seizing to the hub,,,alittle goes a long way,,do not get it on your calipers!!
Old Oct 18, 2011 | 09:50 AM
raidscsi's Avatar
raidscsi
Originally Posted by EaTmYtAiLpIpEs
I don't torque my wheels. I think a 300lb compressor with the impact gets them on tight enough ;-)
Exactly, zig-zag tightening pattern, 1-2 seconds of impact after they stop spinning and there on.
Old Oct 18, 2011 | 02:20 PM
mwsF250's Avatar
mwsF250
As an engineer, I have to speak up and caution you that if you have a decent rattle wrench, that is way too much. Most good wrenches can apply well over 200 ft-lbs. That is enough to plastically deform the studs - permanently stretching and weakening them. Eventually, they will fail. Please do not blame Ford when they do.
The reason for a torque spec is to avoid this. You want to stretch the stud so it keeps the nut under constant tension to prevent loosening, but you must limit the stretch to the elastic zone of the bolt. This is a relatively narrow zone.
Old Oct 20, 2011 | 11:03 AM
79-f250-460
if you put never seize on lug nuts you have to drop the wheel toruqe by 20 ftlbs or you will over tighten
Old Oct 20, 2011 | 11:10 AM
cartmanea's Avatar
cartmanea
It can actually make much more than 20 ft-lbs difference. Lug nuts and studs should be clean and dry.
Old Jul 17, 2018 | 07:34 PM
ITSBOBMD's Avatar
ITSBOBMD
Where's the like button? Nothing on bolts/ nuts that specify dry torque.. easy to overtorque and damage the the threads/bolt.. read above above the elasticity of bolts.
Old Jul 17, 2018 | 08:10 PM
82_F100_300Six's Avatar
82_F100_300Six
WOW.....this thread reminds me of why I put my vehicles on jack stands and take the wheels to tire places......
foothills321
Dec 5, 2014 07:37 AM
cmcstotts
2009 - 2014 F150
Aug 29, 2013 08:56 PM
earlybirds
Nov 6, 2009 01:14 AM
jcee
2004 - 2008 F150
Mar 24, 2009 07:41 PM
samckernan
Sep 3, 2004 10:28 AM
