I wanna know about how many MPG im getting with my 302, its got a oversize cam and gear to gear timing and performance dizzy, behind that is a NP 435. and Im running a ford 9inch with 4.50 gears..
Also what do the gear ratio come out to be?
Im wanting something that has a little lower gears because when you get to 3rd gear it kind of boggs down, would getting a different ratio rear end help? Like what ratio?
I know your prolly thinking this is a weird setup with a 1976 f100 2wd with a built 302 and a NP 435 with 9" with 4.50 gears...Would you have this setup?
As Mil1ion has already said, the 302 is not a torquey engine. It reaches its peak hp and torque at too high of an rpm to make it very useful for towing. Your second problem is the NP 435. I have this same trans in my truck and the gears are spaced far apart making it hard to get the power to the ground without bogging for second or so. Even with the built 390 I have in my truck, i still have this problem. One thing you could do if you have not already is switch to a 4V carb and intake. This will give you good full throttle acceleration and even decent mileage if you choose the right carb. For a 302, an Edelbrock 500 cfm would be adequate and would get good mileage if you stay on the primaries. You don't want that axle ratio to get any lower or you will really suck gas. For a truck like yours, I would go no lower than a 3.73. Bottom line is, if you want to save gas; raise the gear ratio to 3.25, put a healthy carb on it, make sure you keep it tuned up, and keep your foot out of it. If you want to tow with it, you would have to swap in a 351W or a big block to get the adequate torque. In order to get that torque, an engine needs a long stroke. The 302 is a very short stroke engine, causing it to be kind of handicapped in this area.
