Which O2 sensor is it?
Old Apr 2, 2007 | 09:33 PM
live2hunt's Avatar
live2hunt
Had the codes printed out yesterday, and I it's telling me an O2 sensor is bad.
Code is 172 H02S SYSTEM LEAN (BANK 1).
Which sensor is it? I don't know how many there are or which one it is referring to.
There was another Koeo CODE 111 System pass code No faults detected during Koeo test.
Old Apr 3, 2007 | 01:54 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Bank 1 is the passenger side, and it would be the "upstream" sensor, in front of the converter.
Keep in mind a LEAN code doesn't necessarily indicate a faulty Oxygen sensor... all it means is that the computer is receiving information that BANK 1 is running lean. Personally, I'd be suspecting a vacuum leak before an O2 sensor.
What size engine do you have?
Old Apr 3, 2007 | 02:58 PM
live2hunt's Avatar
live2hunt
I'm sorry . . . it's the '93 with the 4.0L
Old Aug 10, 2007 | 01:54 PM
RangerRuss's Avatar
RangerRuss
Changing the o2 sensor on the passenger side of the 4.0 is fun. It is on the front side of the exhaust pipe and not a lot of room. The pigtail has to be fished up the firewall side of the engine block and plugged in. The driver side is a snap to change by comparison.
Russ
Old Aug 11, 2007 | 01:37 PM
7622RM's Avatar
7622RM
Here's a post I made about getting the passenger's side O2 sensor out. https://www.ford-trucks.com/forums/6...en-sensor.html
Your situation comes down to this: Is the O2 sensor indicating a true lean condition? Or, is it malfunctioning? If you truly have a lean condition, you'll have to look elsewhere for the problem. There are many proponents who say that O2 sensors don't go bad, even after 14 years of use, so it wouldn't do you any good to waste your money on a new O2 sensor.
However, that O2 sensor is 14 years old. It might be malfunctioning. If you don't have any heartache over spending $50 on a new O2 sensor, it may fix your problem.
88dually
Mar 16, 2012 01:43 PM
e1p1
Mar 19, 2008 09:32 PM
Silentst2000
15
Jul 8, 2007 06:26 PM
live2hunt
Apr 3, 2007 09:02 PM
rgreen01
Jan 3, 2005 12:25 PM
