Caster Camber troubles again
Old Jul 18, 2007 | 07:53 PM
cbslayer's Avatar
cbslayer
Unhappy Caster Camber troubles again
1987 f150 4.9l lariat 2 wheel driveso far I have replaced upper and lower ball joints on both sides and put new springs on and still leaning in at the top pretty bad auto parts store told me that they sell degreed collars for the top of the ball joint but I want to fix the problem not duct tape and bubble gum it now where the twin I beams connect to the frame in the center the guy got me confused he says the sell degree bolts for that too I was wondering if that was true or did I confuse what he was saying?I really need to get this fixed because I need front end alignment my tires are wore bad on the outsides and I have new set to put on but I cant until I resolve this problem can anyone give me some advice should I take it to the shop and have them fix it ?
Last edited by cbslayer; Jul 18, 2007 at 07:55 PM. Reason: year model and 2 wheel drive
Old Jul 18, 2007 | 08:11 PM
87broncII17's Avatar
87broncII17
Your upper ball joint should have fit into an alignment collar putting collars in with different angles will adjust camber and that is your problem because if your caster is off that will not make your tires wear unevenly because caster cannot cause tire wear
Old Jul 18, 2007 | 08:23 PM
cbslayer's Avatar
cbslayer
how can i find out what degree collar to buy can i use one for carpenters?
Old Jul 19, 2007 | 05:50 PM
87broncII17
You would have to put it on an alignment rack and see how much it is off
Old Jul 20, 2007 | 09:32 PM
cbslayer's Avatar
cbslayer
kool ill take it to the shop in a week or two ill let you know what they say
johntpr
May 28, 2013 10:57 AM
boosteddsm
16
Aug 9, 2011 07:34 AM
Dan92
Jun 21, 2011 12:17 PM
zlusmc
May 19, 2011 01:19 PM
kc 300EX
Nov 13, 2010 10:56 AM
