Bronco II Ford Bronco II
computer
Old Jul 18, 2007 | 02:06 PM
dogg16's Avatar
dogg16
computer
thinkin about swapping the computer..if i can find it..86 br2 where is it located? any special tools i need?
Old Jul 18, 2007 | 05:28 PM
fl1a's Avatar
fl1a
It is located under the kick panel on the passenger side. It shouldn't take any special
tools. disconnect the battery before unplugging it or reconnecting it. It must be
replaced only with a similar computer: same year, same emission setup, same engine,
same transmission. Be sure to check codes beforehand to make sure that is what you
need to do. That could be a bit expensive if another fault is causing your problem.
Old Jul 18, 2007 | 05:49 PM
dogg16's Avatar
dogg16
i dont know how to do the code thing..but i'm looking at a junkyard swap so shouldn't be much...would the codes tell me if the overdrive was bad??
Old Jul 18, 2007 | 06:54 PM
fl1a's Avatar
fl1a
Take a look at the "read first" portion of this forum. It has the codes and a cheap way
to get them. Also the Haynes repair manual lists several codes for transmission
function.
Old Jul 18, 2007 | 07:10 PM
dogg16's Avatar
dogg16
i have that manual...thanx
Old Jul 20, 2007 | 03:05 AM
rebocardo's Avatar
rebocardo
In the FWIW category, the main thing to look for in a junkyard swap is auto to auto and manual to manual. 1986-1987 and 1988-90 might be advisable too.
Old Jul 24, 2007 | 03:18 PM
dogg16's Avatar
dogg16
I found a computer from a 88 mine is an 86 they look similar..i got it for $12 so i'm maybe gonna take a chance...anything i should do b4 puttin this one in???
Old Jul 25, 2007 | 07:29 AM
kernel-panic's Avatar
kernel-panic
The 88 computer may not work, as the '88-up models didn't have the EGR setup, if I remember right. When you pulled the '88 computer, you should have taken note on the wiring and wire colors in reference to the connector to see if things match up... not to say they'd be totally different, but Ford tends to change their wiring configurations year to year...
Old Jul 30, 2007 | 10:43 AM
dogg16's Avatar
dogg16
well i swapped computers and still no overdrive..every thing else works but the over drive so i guess its not the computer..tranny is recently rebuilt..don't know what else to check unless maybe the solenoid if i can find it
Old Jul 30, 2007 | 10:59 AM
dogg16's Avatar
dogg16
i see a lockup solenoid for $13 maybe i should try that..hate to waste $ replacing stuff..is there a way to test it?
Old Jul 30, 2007 | 11:41 AM
kernel-panic
Not that I am aware of off the top of my head. Sounds like the solenoid(s) that drive(s) your overdrive are faulty or there may be a wire connector not connected on the transmission. I would also swap your original computer back in just to make sure everything is 'original configuration' regardless of what you find (bad solenoid(s) or disconnected / bad wiring).
xjcamaro89
2004 - 2008 F150
Oct 19, 2008 07:31 PM
150ford
Nebraska Chapter
Feb 11, 2008 06:48 PM
SuperSnake
North Carolina Chapter
Jun 20, 2007 09:16 PM
sglaine
New Hampshire Chapter
Apr 19, 2005 08:32 AM
hhandel
Mar 4, 2005 09:32 AM
