new front brakes
Old Jul 18, 2007 | 06:43 AM
grandmas 77 f150's Avatar
grandmas 77 f150
new front brakes
I left behind putting 4 wheel discs on my truck and decided to go with an upgraded front brake. I already have discs and would like to go with a larger drilled/slotted rotor and better calipers (4 piston).
My question is, What parts do i need to get to do this, and do they make kits for this kind of upgrade. Keep in mind I have a 77 4x4 f150.
Old Jul 19, 2007 | 09:48 PM
grandmas 77 f150
anybody have any suggestions on this?
Old Jul 19, 2007 | 10:08 PM
77red4x4's Avatar
77red4x4
I haven't researched new rotors, but I do have a few suggestions:
1. Search the forums if you haven't already--it's a good idea to let people know you've searched. I'm sure someone has already asked the same question. Having said that, I'm sure I've asked the same question as others, too.
2. Check in the Brakes, etc forum https://www.ford-trucks.com/forums/forum64/
3. Sometimes it takes folks a few days to get back with you on a post. I'm sure someone in here has an idea for you it just may take them a day or two to get back with you.
BTW, welcome to the site. There's a wealth of knowledge in here.
Cheers, 77red
Old Jul 19, 2007 | 11:41 PM
RNOVRIT's Avatar
RNOVRIT
Assuming you have a Dana 44 front axle and 15" wheels:
In order to change your caliper to a four piston caliper like from Wilwood, Brembo, etc, you will have to make a new caliper bracket. If you want larger rotors, not only will you have to make a new caliper bracket for your new or old caliper to clear the disc, you will have to purchase a larger wheel to clear the caliper. You might want to try and contact Dyna-trac. They might have a kit for a different spindle/nuckle assembly that has a larger rotor and caliper that still has a 5-5 1/2 lug pattern. I used a Wilwood 6-piston ultra-light caliper on a Dana 60 with a five lug conversion assembly from them. I didn't have to purchase larger rims because I did not change the rotor size but I did have to install a 1" wheel spacer to make the back of the rim clear the side of the caliper. I also had to fabricate the caliper bracket to make them mount to the spindle/nuckle assembly. What you want to do can be done but it will take some work. I don't advise getting into fabricating braking parts unless you are a skilled fabricator and know how various parts will react together. A pre-engineered kit would do the best job and be the safest. You might not get the 4 piston caliper or larger slotted rotors but you know it will work correctly.
On a second note, what size tires are you running?
Old Jul 28, 2007 | 12:09 PM
grandmas 77 f150
i have 15x8 rims
Old Jul 28, 2007 | 11:00 PM
RNOVRIT's Avatar
RNOVRIT
With 15 inch wheels you will not be able to use a larger rotor. You will have to run 16 inch or larger wheels to clear the caliper on a larger rotor. You could always use the nuckle, spindle and brake assembly from an F-250 with a Dana 44 and see if anyone makes a rotor in that size with a 5-lug bolt pattern. This way you can get a 2 piston caliper and a larger rotor.
eb76adam
Dec 15, 2012 01:28 AM
pdrhodes1
Mar 24, 2009 12:20 AM
cts1954
18
Aug 21, 2006 05:28 PM
2classics
1966 - 1977 Early Broncos
Mar 29, 2006 11:31 PM
fordtruckn
Nov 10, 2004 08:52 PM
