1966 - 1977 Early Broncos
outer axle shafts
Old Mar 19, 2006 | 09:19 PM
2classics's Avatar
2classics
outer axle shafts
Are the outer axle shafts too different between the 74 drum setup and a f150 disc setup? I forgot to look today. Going to put 77 f150 disc brakes on the 74. Right now I have the small ujoints in the bronc. Upgrades are planned but just to get it on the road, can I use the same outer, or do I need to change the shafts?
Old Mar 28, 2006 | 06:48 PM
Boba Fett's Avatar
Boba Fett
I think to make the work you need the whole knuckle from the F-150, and you need the 77 Bronco drag link setup for steering.
Old Mar 29, 2006 | 06:15 PM
Stroker_Deezel's Avatar
Stroker_Deezel
yes, the shafts are the same, my hubs came off my 78 Bronco
Old Mar 29, 2006 | 09:29 PM
2classics's Avatar
2classics
Thanks on the axle shafts. I have the whole setup from the 150. I parted one out. As for the steering , I have a couple options I'm going over. Don't know which way to go yet.
Old Mar 29, 2006 | 11:31 PM
Stroker_Deezel
For steering, i recommend Checking out BC Broncos Heim Setup, its only about 280 for the whole steering setup
cabloom300
Apr 30, 2010 03:33 PM
Oval_obsessed
Offroad & 4x4
Nov 27, 2006 01:26 PM
