Performance tips for ford 260!!
Old Nov 22, 2001 | 05:07 AM
cricket's Avatar
cricket
Looking for performance tips for a ford 260 motor. what do you suggest as far as intake and carb? Any suggestions on headers? All ideas are welcomed.
Old Nov 23, 2001 | 07:44 AM
lanero's Avatar
lanero
Check this place out:
http://www.cliffordperformance.com/
Roger
Old Nov 23, 2001 | 01:30 PM
Bill_Beyer's Avatar
Bill_Beyer
The 260 is a V8. Clifford specializes in 4s & 6s. Just about anything that applies to a 289 will work with a 260. Stay with a 600 CFM 4 bbl and check around to see who sells intakes & headers for that motor. What's it going into?
Old Nov 23, 2001 | 04:12 PM
cricket's Avatar
cricket
Thanks Bill,
I purchased a 1975 Ford Pickup and the motor was just recently rebuilt by the previous owner. I would like to pep it up a bit, nothing drastic. I just finished installing dual exhaust with Flowmaster Mufflers. The carb is in need of a rebuild, so I figured it was as good as time as any to make a carb and intake swap. Thanks for the info.
Ken
Old Nov 23, 2001 | 04:40 PM
Bill_Beyer's Avatar
Bill_Beyer
>Thanks Bill,
Are you sure it's a 260? I'd be more inclined to think it was a 360 FE motor. Whole different family of engines from the 260/289/302 motors. Ford trucks never came with 260s stock but it could have been swapped.
Old Nov 24, 2001 | 03:31 AM
cricket's Avatar
cricket
Bill, the motor was swapped in from the former owner's 64 Falcon Conv. which was totaled out by a drunk driver. This happened about a month after he completed the rebuild on the motor. The truck at that time needed a motor so he made the swap and sold the truck to buy another Falcon. The motor runs great, just need a little more pep.
Ken
Old Nov 24, 2001 | 09:18 AM
Bill_Beyer's Avatar
Bill_Beyer
Cool, I had a 260 in a 63 Fairlane I resto'd and it was a spunky little engine. Edelbrock makes the Performer 289 intake which fits a 260 and they have 3 different 4V carbs, a 500, a 600 and a 650 cfm. Just remember a 260 is a little V8 so I'd probably go with the 600 at the most.
Old Nov 25, 2001 | 04:23 AM
cricket's Avatar
cricket
Thanks for the info Bill. I will check out the 298 Performer intake.
Since the truck is going to be used mainly for local driving, I'm leaning toward the 500 CFM Carb. I'll probably call Edelbrock and see
what they recommend for a Carb. Thanks again,
Ken
Old Nov 27, 2001 | 01:17 PM
BB's Avatar
BB
Hey, I had a 260 in my ’63 Falcon Sprint Convertible! When it needed a valve job, I swapped the heads for some early model 289 ones. They have bigger valves and a slightly larger chamber but still use the slot-guided pushrods with the fully adjustable rockers, a lot better than the later rail rockers IMO. Then the induction was changed out for an Edel. Torker and a Holley 600 cfm vacuum secondary. Rounded it off with a cam and some headers, man it was like night and day. Thing is, this was not a torque motor but it loved to rev. In a truck I’d run a dual-plane instead as bill suggests and don’t go wild on a cam if that’s in the plans later. See if you can find some tri-y headers to bring up the bottom end.
Keep in mind that you have a 5-bolt belhousing if you plan to make any changes there later.
Barry
Old Nov 27, 2001 | 03:47 PM
cricket's Avatar
cricket
Thanks for the info Barry. Future plans do not include a cam change,but headers are definately in the future. Installed a beefed up C4 along with 350 gears. Hopefully this combination will work well to help the 260 move the truck at a quicker pace. I'll check out the headers that you recommend.
Thanks, Ken
Old Nov 28, 2001 | 07:20 PM
quick6's Avatar
quick6
Old Jul 10, 2019 | 08:18 PM
David Peters's Avatar
David Peters
260/351w question
Barry
I have an opportunity to swap a 351w out of my 65 f100 and put in a good 260. Will the headers bolt up or will I be out of luck and looking for a set?
Old Jul 10, 2019 | 08:40 PM
Tedster9's Avatar
Tedster9
Welcome to FTE David. It's easy to overlook posting dates here, I've done it myself. BB hasn't logged in since 2007, so it's unlikely he'll answer. Maybe try posting your question again as a standalone new post. Should be some folks ready to help though.
hp246
45
May 28, 2026 10:06 PM
Freewilly14
Mar 17, 2014 07:32 PM
260falcon
Dec 16, 2005 02:27 PM
Jigsaw
Nov 11, 2003 08:58 PM
bobcatyo
19
Feb 23, 2003 08:00 PM
