Sponsored by: Auxito
Adding r134a........which port??
Old Jul 17, 2007 | 06:44 PM
z 97ford1's Avatar
z 97ford1
Is it located on the accumulator/drier bottle?
Can I use one of those $16 autozone gage setup and a $10 can of r134a?
Old Jul 17, 2007 | 07:06 PM
Ultramagdan's Avatar
Ultramagdan
You can use the gauges but do you really want test your $1300 system with a set of cheap gauges? Low side tap is between the evaporator and the compressor and should be smaller than the high pressure tap.
Old Jul 17, 2007 | 10:11 PM
projectSHO89's Avatar
projectSHO89
..make that "cheap Chinese-made junk" gauge..
The low side port is directly on the accumulator can.
Steve
Old Jul 17, 2007 | 11:22 PM
z 97ford1's Avatar
z 97ford1
Found it. Thanks
With a gage hooked up on the low pressure port and the a/c running on high, what should the p.s.i. be?
Old Jul 18, 2007 | 12:18 AM
LxMan1's Avatar
LxMan1
It depends on the air temp. Usually between 35 and 45lbs.
mattnj
Dec 7, 2016 07:32 AM
makthenif
1997 - 2003 F150
Sep 5, 2016 11:01 AM
Christopher Layton
Dec 6, 2015 05:17 PM
1990Fordf150v8
13
Jun 22, 2004 01:08 PM
BigNish
Aug 20, 2002 02:23 PM
