transmission help
Old Jul 17, 2007 | 05:37 PM
jmunkie13's Avatar
jmunkie13
transmission help
I have an automatic transmission on my way home today everything was working fine then all of a sudden while pulling out from a stop sign my truck would no longer shift at all.....I pulled off the road and then tried reverse....no reverse at all....the seedomoter was working fine...the OD light was blinking...did not overheat the tranny only around 170........any ideas????????
the only code was P0782
Old Jul 17, 2007 | 06:02 PM
ernesteugene's Avatar
ernesteugene
I assume you tried manual 1 & 2 using the shift lever, and checked the fluid level in Park.
My shop manual (early 99) lists a PO781 and a PO783 as solenoids and other internal components and a flashing OD light. I don't see a 782 in my manual, but it's almost 10 years old.
Old Jul 17, 2007 | 06:04 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
P0782 2-3 Shift Malfunction
Not sure what exactly that means though.
Old Jul 17, 2007 | 06:10 PM
jmunkie13's Avatar
jmunkie13
Fluid Level Was Good??????????????
Old Jul 17, 2007 | 06:24 PM
ernesteugene
I also found this in my manual. No forward and no reverse gives no electrical causes, and the hydraulic/mechanical routine #307 says check fluid level and converter drain back valve. It says inspect valve and perform a drain back test. If the main pump seal went, I think you should be leaking fluid?
Old Jul 17, 2007 | 06:26 PM
jmunkie13's Avatar
jmunkie13
No Fluid Leak
Old Jul 17, 2007 | 06:31 PM
dryfly's Avatar
dryfly
I believe he has one forward gear.I think he is saying it won't shift into higher gears.If I am mis reading I apologize
Old Jul 17, 2007 | 06:40 PM
jmunkie13's Avatar
jmunkie13
You Are Correct Sir 1 Forward Gear Only
Old Jul 17, 2007 | 06:47 PM
ernesteugene
Check the two electrical plugs, one near the shift lever on the drivers side and the other main plug on the passenger side for water or other damage. Try 1st and 2nd using the lever.
Old Jul 18, 2007 | 06:27 AM
jmunkie13's Avatar
jmunkie13
Do you mean on the steering column???
Old Jul 18, 2007 | 01:26 PM
ernesteugene
No, the only potential problem there is with the wire going to the OD switch, and that's not your problem.
Crawl under the truck and find the tranny, and first look at the drivers side where the shift linkage bolts to the tranny case. There's an electrical plug hooking into the switch there that sends gear selection info to the PCM. On the passenger side, up high where it's hard to see, is the main harness to the tranny. That connector is an upside down cup that will hold water if any gets in there and cause shifting problems. I know this because it's happened to me.
breeze4820
19
Feb 14, 2017 03:15 PM
The67Beast
Offroad & 4x4
18
Nov 8, 2007 08:31 AM
brettwingfield
Sep 16, 2007 09:14 PM
fuddy
Aug 26, 2007 02:08 PM
chevyhater74
1983 - 2012 Ranger & B-Series
Jun 26, 2007 01:10 PM
