no shifting
Old Jul 17, 2007 | 05:14 PM
jmunkie13's Avatar
jmunkie13
no shifting
I have an automatic transmission on my way home today everything was working fine then all of a sudden while pulling out from a stop sign my truck would no longer shift at all.....I pulled off the road and then tried reverse....no reverse at all....the seedomoter was working fine...the OD light was blinking...did not overheat the tranny only around 170........any ideas????????
Old Jul 18, 2007 | 08:26 AM
SLAYER1's Avatar
SLAYER1
How many miles on your truck? Mine did the same thing at 101k. Unfortunatly it needed a new tranny.Hope yours is something else.Not sure if my o/d was blinking.I was 200 miles from home so I had other things on my mind, like what the heck do I do now?
Old Jul 18, 2007 | 10:25 AM
jmunkie13's Avatar
jmunkie13
only 77000 miles
Old Jul 18, 2007 | 02:36 PM
WA02Excursion's Avatar
WA02Excursion
Have you checked the electrical connections? There is the shift linkage connector on the drivers side of the trans and also another connector on the passenger side of the trans (hard to see, it is above the back corner of the pan). The first connection tells the transmission the position of the shift lever. The second is to the shift solenoids that control the shifting of the trans. There is a fuse that also ties all of the electronics together (19 or 20??).
Old Jul 18, 2007 | 02:51 PM
Casey's Avatar
Casey
When the OD light flashes a code is stored in the PCM's memory. The code will stay there for about a month even if the light stops flashing. Get the code read. Any diagnosis without the code is a waste of time.
The places that can read codes free can't read trans codes. You might have to go to a trans shop or a dealer.
Old Jul 18, 2007 | 04:27 PM
ernesteugene's Avatar
ernesteugene
Why did you start a new and identical thread on the same problem? Didn't you like and follow up on the answers given in your original version here? https://www.ford-trucks.com/forums/633234-transmission-help.html I'm still waiting to hear back on the items I suggested on that thread! Have you tried manual 1st and 2nd, and checked the connectors as I suggested?
Old Jul 18, 2007 | 05:21 PM
SLAYER1's Avatar
SLAYER1
I think he started this one first and he doesn't mention the trouble code in this one but the other one he does.
Old Jul 19, 2007 | 07:40 AM
jmunkie13's Avatar
jmunkie13
the double posting was a complete accident ...sorry... I have been trying to keep up with both.
I did run a diagnostic and only pulled code p0782
no problems with the connectors mentioned in the other thread
Old Jul 25, 2007 | 01:33 PM
jmunkie13's Avatar
jmunkie13
SORRY FOR NOT LOOKING FOR SO LONG BUT i WAS OUT OF TOWN FOR WORK...
tORQUE CONVERTER SHOT AND TRANSMISSION TRASHED.......REBUILD AND NEW TORQUE CONVERTER IN PROGRESS...
My warrenty company is giving me hassle....no surprise......they are replacing all of my u-joints for free but will not touch the transmission.....does anyone have any ideas on how i can pressure them into covering the repair??????
Old Jul 25, 2007 | 02:29 PM
7.3L DID TD's Avatar
7.3L DID TD
Bummer! What reason did the insurance company give you for not touching the transmission? Was the insurance coverage FoMoCo? See this is why I didn't buy one for my truck, those SOB's know they hold the reins! B@st@rds! I purchased one for my 5th wheel and it expires in August 2008 and I have never had to use it, what a waist of money. I kinda hope something breaks so I can feel like I got my money's worth! No not really! I do have a Dometic refrigerator recall but that's another story. Sorry to hear about your transmission, hope you get back on the road soon...
Old Jul 25, 2007 | 08:18 PM
Casey's Avatar
Casey
Here's why they should not cover the repair:
AFE STAGE 2, MBRP 4" DUALS, EDGE EVOLUTION +EDGE JUICE W/ ATTITUDE BETA
It died from too much power, not a defect. The warranty is to cover manufacturing defects, not someone that adds a bunch of power.
Flame away.
Old Jul 26, 2007 | 11:08 AM
jmunkie13's Avatar
jmunkie13
hey casey.....I didn't ask why they shouldn't....if you could read I asked if anyone knew how I could pressure them....also they must show proof that the upgrades caused the damage....they are refusing to show proof....thanks everyone for your help and for all the ideas of what to look for......Casey...thanks for nothing.
