Power Brakes
Old Jul 17, 2007 | 02:47 PM
fordtuff125's Avatar
fordtuff125
Power Brakes
Well last week coming back from Ohio I lost the power brakes in a traffic jam in a 1996 f350 dully. the vacuum hose is not plugged it has vacuum I think it is the power booster or the diaphragm in it? What do you guys think.
Old Jul 17, 2007 | 02:52 PM
ajbeiler's Avatar
ajbeiler
sounds like a power booster. how clean is the brake fluid?
Old Jul 17, 2007 | 03:24 PM
fordtuff125
The fluid is clean. thats what I think it is. It happened coming back from UNOH to
Old Jul 17, 2007 | 03:26 PM
tjbeggs's Avatar
tjbeggs
Makes sure you have vacum by measuring with a gauge. Just doing it by feel is not enough. its should have 18 in hg or more.
by the way welcome to FTE!
ajbeiler's Avatar
ajbeiler
no way where you from? im in school right now here at unoh. im from lewis brug w.v
Old Jul 17, 2007 | 03:28 PM
tjbeggs's Avatar
tjbeggs
And I graduated from there! small world!
Old Jul 17, 2007 | 03:37 PM
wreckit72's Avatar
wreckit72
I had to replace mine a couple of years ago. I had the same loss of power assist. I would check your vacuum reading first though. The vacuum pump will be cheaper and easier if that is your problem.
Old Jul 17, 2007 | 03:58 PM
Neal 97 250's Avatar
Neal 97 250
You can laso convert it to hydraulic if you want mega brakes. Search here to find info on it. I have seen alot of threads about this. It is alot of work but they say it is worth it.
Old Jul 17, 2007 | 08:19 PM
fordtuff125
I start august 20th in high performance how long have you been there? I'm from St. Clair MI
I will test the vacuum tomorrow any idea how much the gauges are?
