351W roller cam block
Old Nov 20, 2001 | 08:53 AM
4byford's Avatar
4byford
Before I begin looking for a 351W, I am trying to determine if a roller cam block is available for the 351. I know that the 302/5.0 had them from 85 (HO) and 91(?) for the standard blocks; did Ford ever make the 351 with a factory roller? I am not interested in the aftermarket conversions due to cost and cam availability; would like to find a block compatible with the factory roller lifters and cam (like the 5.0s). Anybody know about this? Thanks!
Old Nov 20, 2001 | 01:30 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
My 351 W has Ford Racing high performance hydraulic cam shaft M-6250-A332 and roller rocker arms. Available from Ford Motorsport. Is that what you are looking for?
Old Nov 20, 2001 | 06:34 PM
4byford's Avatar
4byford
I am not sure, but I think that is a hydraulic flat tappet camshaft (no little wheels on the lifters!), although the rocer arms are roller. I am trying to find a block set up for a factory roller cam. Maybe it doesn't exist, and only the 5.0 302's are set up for it.
Thanks for the reply-
Old Nov 28, 2001 | 07:28 PM
quick6's Avatar
quick6
try a 351 w from a 94-96 f150/250 truck or bronco and of course the lightning had it also but good luck finding one of those engines
hope this narrows your search
Old Dec 18, 2001 | 06:49 PM
Reueld's Avatar
Reueld
Yes Ford makes a 351 roller block. Get hold of the Ford MotorSport SVO catalog available from Ford and you will see it in there. I have a 351W with the conversion roller kit and yes the cam selection is definitly smaller but certainly adequate for the street. I have had it for about 3 years now and have had no trouble with it at all.
Old Dec 18, 2001 | 09:16 PM
Franklin2's Avatar
Franklin2
87crownvic2door
16
Dec 24, 2014 05:51 PM
BigRy
Nov 14, 2009 12:38 PM
sparky
May 21, 2009 08:33 PM
Mr. Bob
Oct 9, 2005 05:47 AM
4byford
Nov 25, 2001 11:07 PM
