Bronco II Ford Bronco II
Sputter and Backfire
Old Jul 16, 2007 | 09:36 PM
broke77f100's Avatar
broke77f100
My 1987 Bronco II has been having trouble for about a month. It tends to sputter at any speed(idle-WOT)...And it backfires when i slam the throttle quck and let off. The sputtering is probably due to an oxygen sensor right? And i should change the plugs and wires of course. But what would cause the backfire? And another question..does anybody know if Pacesetter headers and y-pipe have the spot for an oxygen sensor on them?
Old Jul 16, 2007 | 10:06 PM
87 XLT's Avatar
87 XLT
When my 87 was backfiring I pulled the codes & got a code 14, swapped the ignition module. Problem solved.
Pull the codes & let the computer tell you what the problem is.
Old Jul 16, 2007 | 11:44 PM
kernel-panic's Avatar
kernel-panic
I agree with pulling the codes. Something is amiss. You could also have a lot of gunk in your intake / throttle body, not to mention possible timing and ignition issues -- I am thinking more of a pickup/module issue. As far as the headers, I do believe that the Pacesetters have the O2 sensor bung on the Y-pipe.
Old Jul 17, 2007 | 02:52 AM
rebocardo's Avatar
rebocardo
No, a bad O2 sensor will not do that.
Most likely a bad TFI, especially if you do not throw a code or check engine light.
The sputter you described is many times lack of ignition spark.
The other thing it could be is a marginal charging system about to die that is borderline at 12 volts. Easy enough to test with a DVM and hand blipping the throttle linkage under the hood and testing the battery at rest and with a load test.
Old Jul 17, 2007 | 09:49 AM
broke77f100
yeah my throttle body is a bit grimey inside..i will clean it soon...the truck isnt on the street at the moment so it doesnt matter what i do to it haha.
wahlturfcare
Aug 13, 2013 10:05 PM
ljemmer465
Apr 2, 2013 09:43 PM
bdunegan
13
Jun 13, 2010 10:18 PM
pidaster
13
Nov 8, 2009 10:43 PM
Brian A
Apr 4, 2004 08:35 PM
