Calling all transmission gurus!
Old Jul 30, 2007 | 04:28 PM
  #121
andym's Avatar
andym
Originally Posted by Skandocious
The noise is reminiscent to the sound of a VERY strong wind blowing underneath the cab
Does this sound like it could be gear howl? Especially given the last post where Chris says the noise comes on when he lets off the gas?
Old Jul 31, 2007 | 09:10 AM
  #122
archangel's Avatar
archangel
I have to say I'm a bit disappointed with this Transmission forum. I receive much more help from the guys in my 87-96 forum. The only people that ARE replying seem to be the ones that are still subscribed to this thread from before it got moved...
Some of us only come here once in a while.
I'm asking a SUPER simple question here. Is the torque converter supposed to disengage completely when you let off the throttle (so that the RPMs will then fall)?
If the OD cancel light is on then it will drive like a manual trans when slowing down.
But feeling the TQ clutch letting go should not be noticed as the coast clutch has not been activated so the trans should let the engine drop some serious rpm's any time the throttle is let go, regardless if the torque converter letting go or not, and you are coasting in drive and the OD cancel light is off.
To notice if the TQ is still locked up, as you come to a stop in first gear it will feel just like a manual trans in first gear and you forgot to step on the clutch, and the engine will lug and die as you stop.
Is it also supposed to disengage when the brake is depressed?
If you are on the brake, I assume you are off the throttle and the reply/answer above would also apply here.
RPM's would drop and you would not notice the TQ clutch remaining locked or letting go.
I really need help here from the transmission experts. I have already had this truck into a tranny shop and the guy could not hear the noise so I am on my own...
There sounds like there is a serious problem and there should be some codes set because of it, and I'm sorry to say that perhaps the "tranny shop guy" should be left alone and you should have a Ford dealer run a scan for transmission codes and see if they can find something the other guy could not.
You don't have to let Ford rebuild it, just have a scan run.
The "state of the art" $75 scanner I used (late 80's and early 90's) when working at the dealership is now like a model "A" compared to the (supercharged EFI) $100,000 S.B.D.S. scanner set up they use now!
Old Jul 31, 2007 | 12:48 PM
  #123
andym's Avatar
andym
Since the PCM runs both the engine and the transmission, codes can be retrieved for both from the same place. I should have thought to ask this earlier, but you did pull the codes, right Chris?
Old Jul 31, 2007 | 01:26 PM
  #124
Skandocious's Avatar
Skandocious
Yes sir, I did pull the codes, that was one of the first things I did. No transmission codes.
dylansf23
Jan 20, 2014 10:29 PM
reverendxlt
Jul 26, 2011 04:44 PM
High_Horse
Jun 7, 2011 02:45 PM
nathan69-360
16
Jun 24, 2009 01:51 PM
David85
Apr 20, 2008 03:32 PM
