77f250 Axle Identification
Old Jul 16, 2007 | 10:05 AM
BRUTIS77F250's Avatar
BRUTIS77F250
I Have A 77 F250 With The 351m 4speed. I Did Find Out That The Rear Axle Is A Dana 60 W/4.10 Open Dif. Is There Any Way, Besides Looking On The Axle, To Find What The Front Axle Is? The Tags On The Axles Are All Rusted Off Of Course. The Reason For This Is I Plan To Put 33x12.5r15 Wheels And Tires On It. Any Help Would Be Great.
Old Jul 16, 2007 | 10:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Look on the Warranty (VIN) Plate for AXLE code. Decode it using FTE's decoder or post the code here. If the code has three digits, it will be possible to ID the front axle.
Three digit code: The first two digits relate to the rear axle, the third, to the front axle.
Two digit code = rear axle only.
Note: On Dana axles, the ID code tags may be bolted (2 bolts each) to the housing to the left of the cover (or right for front axle). The tags are steel, rectangular and about 2" long by 1/2" high. The ID numbers are stamped on the tags. The axle tubes also have stamped ID numbers on them, usually around the top.
Old Jul 16, 2007 | 10:42 AM
BRUTIS77F250
77f250 Front Axle Code
It Has A Code Of 24j Which I Was Told Was A Dana 60 W/4.10 And Thed J Was For Power Steering.
Old Jul 16, 2007 | 10:54 AM
NumberDummy
You're right...
24 = Dana 60 / 4.10-1 / non Limited Slip / 5300 lb Axle Capacity / J = Power Steering
Look for the bolted on ID tags, or the stamp ID numbers on the housing. That's the only other place to ID them.
77 F250 Custom
May 21, 2012 09:56 AM
hevy metal
Jun 15, 2008 07:10 PM
zukitough
17
Mar 3, 2007 09:00 PM
77f2504by4
Nov 7, 2005 02:36 PM
77hb
Aug 22, 2005 09:57 AM
