Differences in 302 oil dipstick
Old Jul 15, 2007 | 08:37 PM
FixinItUp's Avatar
FixinItUp
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have a 1980 F150 with a basically dead 302. I found a 1979 302 for a good price. The only problem is the oil dipstick. The new engine has a front-sump pan, mine is a mid-sump. Since I'll have to swap in my mid-sump oil pan to clear the crossmember, the dipstick won't work. Has anyone figured out a solution to this? The price for the rplacement engine is really good & I'd like to use it.
</TD></TR></TBODY></TABLE>
Old Jul 16, 2007 | 06:30 AM
ken75ranger's Avatar
ken75ranger
Swap the front cover, the oil pan, and the oil pickup tube off of yours. It's not a bad idea to check the timing chain anyways. Or some guys block off the front hole for the dipstick.
Old Jul 16, 2007 | 07:50 AM
FixinItUp's Avatar
FixinItUp
The stick for the new engine is on the front of the engine while the stick for the current engine is mounted on the side. Swapping the oil pan is required to clear the crossmember, but the nre block doesn't have a provision for the side-mounted tube. Any idea how to get atound that?
Old Jul 16, 2007 | 09:18 AM
ken75ranger
If you can't work the front one with your accessories then you will probably have to do an aftermarket on like Lokar.
Old Jul 16, 2007 | 03:56 PM
HemiEater's Avatar
HemiEater
try and find a truck pan with the dip in the pan...or you can drill the block for the dip ...there might be a boss on the block for it or maybe not. I made mine work using a truck 351W pan that had the dip in the pan, I just welded it onto the 302 pan....
I also got a freeze plug for the timming cover.... .300 I think
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
Roger Davis
Nov 23, 2007 03:21 PM
Soilman
Oct 31, 2007 01:18 PM
griz32379
Aug 9, 2007 11:39 PM
MrNuckelhead
Jul 9, 2007 07:39 AM
