What rear end
Old Jul 14, 2007 | 08:50 AM
dryfly's Avatar
dryfly
What rear end
How do I know what rear-end I have.There is no door tag anymore.It has twelve bolts,shaped like a persons head and neck turned sideways?And when I jack up the rear and turn the wheel the other side rotates in the same direction.Not sure but wasnt it if the wheels rotate in same its posi.and if they rotate in diferent direction its limited slip,dunno.I need to know is this a Ford rear,or Danna.limited slip or posi.
oh yea the tag on the pumpkin says;
--409 H
-L73 10 5 CA31
thats exactly what it looks like.thedash marks represent digits I cannot make out.I believe there is something written in those spaces but cannot decifer.
I will be outside working on it so If I donnot respond rite away please dont think I am ignoreing you.Thanks so much for any response.
Old Jul 14, 2007 | 08:59 AM
guzzle92's Avatar
guzzle92
Sterling 10.5" (Ford) 3.73 ratio limited slip
Old Jul 14, 2007 | 02:39 PM
dryfly's Avatar
dryfly
so if its limited slip I have to add some sort of addative to the 75/140 synthetic gear lube.What is it and where can I get it quickly.How much to use.
Old Jul 14, 2007 | 02:47 PM
nlemerise's Avatar
nlemerise
Friction modifier is what you are looking for...Ford or parts store will have it. Add a little and try it out - if the rearend chatters, add a little more until you can make tight turns with no grabbing in the rear. I believe it took about 3 ounces for mine...but my memory is...oh heck, I forgot what I was going to say!
Old Jul 14, 2007 | 03:24 PM
dryfly's Avatar
dryfly
Thank you both for your helpful replies
Old Jul 14, 2007 | 05:52 PM
dryfly's Avatar
dryfly
by the way what exactly told you,from the info given,which rear-end it is.
Old Jul 14, 2007 | 06:00 PM
Uzumati's Avatar
Uzumati
This part L73 10 5 the dash in front of the L would be a 3
If you dont want to fool with the additive use "Royal Purple MAX Gear" it has the friction modifier allready in it.
Old Jul 14, 2007 | 06:23 PM
rebelchevy02's Avatar
rebelchevy02
Your truck description, all the 250s, and 350s in the super duties, with SRW are a sterling 10.5 unless swapped out.
Old Jul 14, 2007 | 06:32 PM
dryfly's Avatar
dryfly
ah that clears it up thanks
Old Jul 14, 2007 | 06:38 PM
rebelchevy02
That also, is what gave it away.
73 designates a 3.73, 10 5 is 10.5" ring gear.
Old Jul 14, 2007 | 06:47 PM
dryfly's Avatar
dryfly
thanks for the tag decifer also.Wasnt sure.On the cover is a piece of white tape.On it says "NO LUBE"do you think they mean this particular one does not have any friction modifier in it or needed.Not holding anyone to anything ,just wondering.I,m going to put it in anyay.aAs explained before.
Old Jul 14, 2007 | 06:53 PM
Uzumati's Avatar
Uzumati
The sticker is put on during manufacturing when they close the pumpkin. It is not filled till later down the line.
Old Jul 14, 2007 | 06:56 PM
dryfly's Avatar
dryfly
Thumbs up
my god you guys are amazeing.How could anyone know that.Thanks for the info.
Old Jul 14, 2007 | 07:42 PM
guzzle92's Avatar
guzzle92
.......the tag on the pumpkin says;
-L73 10 5 CA31
Are you sure that the last 4 are not 0A31?
0 = 2000
A = January
31 = 31st
Build date Jan 31, 2000
Old Jul 14, 2007 | 08:47 PM
dryfly's Avatar
dryfly
I thought it was "CA31" but if it was OA31 that would make sence the truck was manufactured in feb 2000
0 = 2000
A = January
31 = 31st
