steering woes
Old Jul 13, 2007 | 11:07 PM
390Highboy's Avatar
390Highboy
Unhappy steering woes
I am having an awful time with the steering on my 93 f150. It steers hard and the steering wheel doesn't return on its own. If I am driving down the highway, the wheel basically stays wherever I put it, which isn't so bad on a straight stretch but scary on corners. I already tried adjusting the steering box, but no matter where I put the adjuster it didn't seem to make any difference. I've been noticing it getting stiff for quite a while, but it suddenly got really stiff about three days ago when we had an exceptionally hot day with temperatures around 100 F. I'm not sure if the heat really affected it or if it was just a coincidence. If anyone could give me some advice or share their experiences, I would appreciate it.
Old Jul 16, 2007 | 04:10 PM
rattosh51's Avatar
rattosh51
power steering pump going out???got enough fluid in it?
Old Jul 16, 2007 | 08:04 PM
albung's Avatar
albung
4x4??? if so check the u joints where the wheels turn in front axle aka the wheel joints mine were frozen and had to fight it in turns
Old Jul 16, 2007 | 09:55 PM
93XLTFlareSide's Avatar
93XLTFlareSide
I second the notion about the axle joints. Mine froze up last summer, was pretty scary on some turns as the wheel would feel locked into place in some instances. Try locking the hubs and driving, if the front drivetrain makes some god awful clunking then they are shot.
Old Jul 16, 2007 | 10:02 PM
wreckit72's Avatar
wreckit72
I have had the same thing happen on my 95 F-250 lately. Mine is 4x4 so I will definitely check the axle joints out.
Old Jul 17, 2007 | 12:58 PM
wreckit72's Avatar
wreckit72
If your truck is 4x4 definitely try locking the hubs. I locked my hubs to today and got the clunking while turning. You guys were right thanks.
Old Aug 10, 2007 | 06:46 PM
drshoop3's Avatar
drshoop3
so what do you do about the axle joints? I just bought a 93 F150 4X4 and the steerig is really rough. The brakes don't feel so good, either. When I push the brakes gently, I can feel the pedal pulsing under my foot. Any suggestions? The lady I bought it from said it might need rotors.
Old Aug 10, 2007 | 08:12 PM
alz's Avatar
alz
Yes, that would be your rotors. Either have them turned or replace them. Axle joints are just u-joints for the axle. They will loose there lubricant and rust.
Old Aug 10, 2007 | 09:12 PM
netscaner's Avatar
netscaner
Mine was tight and hardly returned to center, turned out to be upper bearing in steering column right below the steering wheel.
MDSLIGHT
May 26, 2014 08:33 PM
plum716
2004 - 2008 F150
Mar 8, 2012 12:20 PM
cbass139
31
Apr 6, 2011 01:22 PM
ranair57
2004 - 2008 F150
Dec 26, 2009 08:12 PM
Fordman79
Jul 3, 2006 03:05 PM
