Stalling when turning
Old Jul 13, 2007 | 09:06 PM
bradpitt's Avatar
bradpitt
Smile Stalling when turning
My 1994 f350 5.8 L stalls pretty regularly when Im turning at a slow speed 1-3 mph. The truck also hesitates and sometimes stalls when I apply gas from a stand still. Are they both TPS sensor related? Please help. Thanks Paul
Old Jul 14, 2007 | 12:23 AM
mebe2k's Avatar
mebe2k
mine does that sometimes, like if i'm backing out of a tight parking space and I need to turn the wheel hard, it will die out.. sometimes it will hesitate upon takeoff, but it doesn't stall..
Old Jul 15, 2007 | 09:16 PM
oldproudvet's Avatar
oldproudvet
You've got a power steering pressure switch issue, when you turn the pump, pressure builds up, takes power. @ idle, it can kill the engine. The pressure switch in the pressure line, from the pump to the steering secto, will send a signal to the idle air control motor, thru the computer, keeping the idle speed proper.
Old Jul 16, 2007 | 07:16 AM
EPNCSU2006's Avatar
EPNCSU2006
The 5.8 doesn't use a power steering pressure switch, to my knowledge...
pajenkins
Mar 12, 2015 06:09 PM
900rr
Dec 22, 2006 06:50 PM
theGman
Electrical Systems/Wiring
Mar 10, 2005 06:55 AM
pcapozza
1997 - 2003 F150
Oct 20, 2003 11:38 AM
