fuel leak
Old Jul 13, 2007 | 02:11 PM
funzjb1's Avatar
funzjb1
fuel leak
I have a 96' F-250 PSD 5 spd. w/ 201,000 mi. I recently noticed a fuel leak coming from a hard line just below the FPR. I can see it drip when running. How do I fix this? Is this piece pressed in or soldered?
Old Jul 13, 2007 | 02:32 PM
c00nhunterjoe's Avatar
c00nhunterjoe
any way to get a picture? the only thing i can think of is the line that is in the fpr housing all it is, is an o-ring in thereonce you take the 2 bolts out of the fpr housing it lifts off of that line, thats all thats coming to mind right now
Old Jul 13, 2007 | 07:44 PM
willbd's Avatar
willbd
is this the fuel retun line?
Old Jul 14, 2007 | 02:22 AM
funzjb1's Avatar
funzjb1
I do not know exactly. It is the only "L" shaped solid line going to the front bottom of water seperartor
Old Jul 14, 2007 | 05:46 AM
tjbeggs's Avatar
tjbeggs
That line just has an 0ring in there to seal. theline just slips into the FPR. I have no idea the part number thought. also could be the o-ring between the FRP and the filter housing. To take it apart just unhook the return line and remove the two 10mm bolts that hold the FPR to the housing.
