Charging System Blues 300
Old Jul 13, 2007 | 12:35 PM
galyejf's Avatar
galyejf
Can anyone help me solve a charging system problem? I replaced my alternator and my cables but my atlernator will not charge the battery. The alternator was bench tested under a load and it passed. I even tried hooking the ground cable to the alternator bracket, but the charging system is not working. Any suggestions? Please
Old Jul 13, 2007 | 01:14 PM
1979f350inline6's Avatar
1979f350inline6
if its and older truck you need to replace the voltage regulator
Old Jul 13, 2007 | 01:38 PM
srercrcr's Avatar
srercrcr
Maybe the battery is defective, not accepting the charge.
Old Jul 14, 2007 | 04:01 AM
85-300man's Avatar
85-300man
Get a voltmeter, and check the voltage at the alternater and at the battery, while its idling. It should be the same or very close. If not you have a problem with your wires. I believe it should charge at around 11 to 14 volts I think (I have been messing with 24 volt systems too long). If it is the same shut off the engine and keep the voltmeter connected to the battery and see if the voltage slowly gose down it should stay at a few volts below what it charged at, and not go down. Hope this helps.
Old Jul 14, 2007 | 07:20 AM
N8N's Avatar
N8N
should charge at at least 14V, will fall to 12.5 or thereabouts.
which reminds me I need to get my alternator tested, it seems a little weak.
nate
Old Jul 16, 2007 | 12:37 PM
galyejf's Avatar
galyejf
Thanks all of the advice. I replaced the voltage regulator and I seems to be working now.
Thanks again,
John
PowerstrokeRyan
Apr 24, 2011 07:36 AM
03BLKEB
26
Jul 3, 2009 04:41 PM
77 bird
Jan 31, 2008 10:02 PM
llehmn
Electrical Systems/Wiring
Mar 26, 2007 09:40 AM
joe2705
Jan 4, 2003 01:32 AM
