Aerostar Ford Aerostar
96 fan removal?
Old Jul 16, 2007 | 03:12 AM
96_4wdr's Avatar
96_4wdr
EEC-V systems
Engine RPM/Vehicle Speed Limiter
The Powertrain Control Module (PCM) will disable some or all of the fuel injectors whenever an engine rpm or vehicle overspeed condition is detected. The purpose of the engine rpm or vehicle speed limiter is to prevent damage to the powertrain. The vehicle will exhibit a rough running engine condition and the PCM will store a Continuous Memory DTC P1270. Once the driver reduces the excessive speed, the vehicle will return to the normal operating mode. No repair is required. However, the technician should clear the PCM and inform the customer of the reason for the DTC.
the firmware rpm limit and veh. speed limiter firmware is listed in the Ford Service DVD of EEC-V systems
many EEC-IV systems only limit max. rpm
Deluxe06
18
Jan 22, 2013 11:19 PM
GraveLayer
Apr 2, 2011 06:08 PM
nsaikia
30
Jul 16, 2007 07:17 PM
sincityrunners
1983 - 2012 Ranger & B-Series
18
Jul 31, 2006 03:29 PM
2000xp8
Aug 16, 2003 05:43 PM
