Lowering options
Old Jul 13, 2007 | 12:36 AM
tfiedler's Avatar
tfiedler
Lowering options
I have a 1995 F150 4x2 with a 5sp manual transmission. I'd like to lower it a little, not for show or anything, but because I think it will float less on the roads. My question... do I need to lower it or is there a better shock option that might stiffen it up a little?
Old Jul 13, 2007 | 06:59 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
There are shocks that are adjustable.......Places like Summit Racing and Jegs carry them. They claim to stiffen things up a lot and offer a better controlled ride. I think KYB brand is one of them. Google their catalogs and you can find more.
Personally I think the center of gravity has to be lowered to really make any difference in the top-heaviness and that "float". You can lower about 2" with lowering spindles or lowering coil springs in the front and either a shackling kit or lowering blocks in the rear. This amount lets you use stock shocks and doesn't mess up the normal alignment, toe-in "etc".
You will see a difference in handling if you lower it, way less lean in corners and a lot of that float will be gone. You will also have a bit stiffer and rougher ride and depending on your tire size, might rub on an occasional RR track or "whoop" in the road if you take them too fast.
See the pics of mine.....I bought it this way and the best we can figure is the PO brought it down in front about 4 and in back about 4-5. Front he did by cranking the torsion bars down...rear he heated the front 6" of the leaf spring and let it settle. Cheap way to do it on the rear and does ruin the spring. Mine rides very stable and corners great with hardly any lean....but it is a rough ride and I have to slow down on tracks and such.
Good Luck
Bob
Old Jul 13, 2007 | 11:41 AM
pud's Avatar
pud
not to attack you but thats BS! my 96 F350 crew cab (6" taller than a stock F150) cut corners better than any truck Ive ever had. The suspension was so damn stiff you peed blood when you got out, but she sure did hug the road!
Do you have sway bars? You can lower it but if you do it on the el cheapo and dont get the proper stuff you can end up with a more floaty feel. Spring rate is the big thing to watch for, the higher the number the stiffer the spring.
Old Cane
Jan 15, 2014 01:34 PM
CTPATRIOT
35
Jul 19, 2012 10:48 PM
abcfisher1
Jun 24, 2012 08:18 PM
gt40racing
May 3, 2006 09:08 PM
glenamac
May 23, 2004 05:20 PM
