Lowering 63 F100
Old May 20, 2004 | 01:41 PM
glenamac's Avatar
glenamac
Question Lowering 63 F100
Newly purchased truck; first posting.........looking for anyone with experience or opinions regarding front and rear lowering using "mono" leaf springs. Good idea or bad idea? I haven't found many options for the 63. Thanks.
Old May 22, 2004 | 10:18 PM
FATPAULJ's Avatar
FATPAULJ
flip the springs its not so hard and not so much work.
Old May 22, 2004 | 11:35 PM
Rosati's Avatar
Rosati
Mono's are one way, flipping the spring perches is another. You could also remove a leaf or two. It really depends on your budget and the end use of the truck.
I believe the monos will work for a cruiser but you can almost forget about using the truck for hauling anything. I installed monos on the rear of my truck and the axle sits about three inches from the frame. I'm either going to notch the frame or run coilovers to help absorb the bumps.
Old May 23, 2004 | 05:20 PM
a63unibody's Avatar
a63unibody
When I was lowering my truck, I took out three leafs in the rear and it RAISED the truck nearly an inch, so I asked a guy at a spring shop here in Atlanta and he said that what happens is that the leafs I took out were straighter that the main leaf, which in turn allowed it to become more arced thus raising the truck!!! So I bought reversed eyed leafs for the front and rear.
Robert
oldgreen63
Feb 7, 2011 05:38 AM
appel400
Mar 16, 2008 10:30 PM
charlie12345
Mar 13, 2008 03:29 PM
braveduck
Oct 7, 2002 12:29 PM
63 diehard
Dec 4, 2001 11:31 PM
