clutch adjustment
Old Jul 12, 2007 | 04:39 PM
97 HD's Avatar
97 HD
clutch adjustment
can anyone tell me if there is anyway to adjust the clutch . i have to press it all the way into the floor HARD, to start the truck .then it also seems like i have to press further than i think i should to shift gears. i was told the clutch was just replaced when i bought the truck last week. Its a 97 F250 HD 4x4 with the 7.3
Thanks
P.S. how do i get a picture at the bottom of my post?
Old Jul 12, 2007 | 05:00 PM
barebackjake's Avatar
barebackjake
no adjustment, check your bushings for the pedal and pedal box. sounds like there wore out. also with a new clutch your disengagement point is gonna be dang near the bottom of the pedal. if your pedal bushing is wore out i and some other people have replaced it with a heim joint so you dont have to deal with the stupid plastic bushing anymore.
Old Jul 12, 2007 | 05:01 PM
Cuda_jim's Avatar
Cuda_jim
There is no adjustment of clutch linkage or clutch pedal position (CPP) is required. But there is a bushing that may need to be replaced. It is under the dash.
Did they replace the master & slave cylinder when the clutch was replaced?
You might not be able to post picts until you get more posts, 25 IIRC.
Old Jul 12, 2007 | 05:02 PM
Cuda_jim's Avatar
Cuda_jim
You're too fast for me BBJ
Old Jul 12, 2007 | 05:06 PM
Cuda_jim's Avatar
Cuda_jim
gravydude
21
Mar 1, 2017 11:51 AM
brendy1962
Jul 15, 2012 12:36 PM
oldblue89
Mar 20, 2011 09:11 AM
Supercab
1983 - 2012 Ranger & B-Series
Mar 7, 2011 06:20 PM
bigdaddyII
Feb 26, 2005 06:15 AM
