Hi....Am posting for a work collegue who hasn't got internet...
He's got a 95 F350 PSD dually...when driving, back off the throttle and it cuts out..turns over ok...starts eventually..but blows white smoke for a few seconds..then ok for miles.....then it'll cut out again.same thing...starts after a bit....white smoke.........dosn't happen all the time.....just now and then....He's recently changed fuel filter, checked lines etc...all seem ok.........Could part of the problem be bio..?....A lot of the service stations here run 5% bio.......Any help would be appreciated...
Sometimes they just cut in and out though from what I understand. Mine has been starting to show CPS symptoms but hasn't completly died yet. Knock on wood.
Mine started stalling at odd times (ie. braking ???) so I changed out the CPS with the new $25 version from FORD. It has not stalled since.
course now I have hard cold start issues.... (*&(*&(*&!!!
oh sorry Erl_berner I was talking to the OP. Your issue are more than likely Glow plug related. Try plugging in the block heater and see if it helps. I know your in Cali but it still could be.
TJ..........Thanks to you all everyone else for the info.......Oil has recently been changed...he used full synthetic...but isn't sure if the spec is correct....we went to our local oil distributor and x- matched the grade and got a UK equivilent spec... Also called a dealer in USA for part number of CPS...located and bought one off Ebay.Waiting for delivery from the USA...Will keep you posted....
oh boy another out of country PSD. that would be an experience! Caseydudem is in Germany and he has the same fun time with parts and what not. Keep us posted!
New CPS arrived from the USA yesterday....work collegue called before.......Fitted up.20 or so mile road test........drives a dream........Said he wished he'd got a spare one now......Doh !!!..
Thanks to all who offered advice etc...much appreciated...
