Adjust your tire choice, so the overall tire and wheel 'size' remains the same, as to diameter, so your clearances and spedometer accuracy don't cause you any trouble.
Sell the 16 1/2" Jackmans on Ebay.
Does your E350 gas tank hold the full 35 gallon spec?
> Are bolt patterns and stud size the same on the new stuff as on the older
> [are they interchangable]?
No, metric, hub-centric, six bolts (as examples).
You will find the best big off road tires (ex. Interco) that come in two sizes with the most choices are 15" and 16.50". For some brands, 16" choices do not exist.
E350 vans did not go to metric in 99, only the trucks did. E350s up to at least 04 are 8 lug X 6.5 ". I bet up to 2007s are the same. The 2008 may have changed to metric but I doubt it. All 8 lug Dodge and Chevy will fit. 99 and older 8 lug truck rims and all 8 lug Ford van rims will fit. All this is supposing the 4X4 conversion company didn't change it to something uncommon.
Thanks for the correction as I assumed that the truck and van switched at the same time
