Brake Problems
Old Jul 14, 2007 | 07:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Will post a picture in just a little.
Old Jul 14, 2007 | 09:11 PM
Dave Sponaugle
The flange on the bracket goes toward the pulley.
This should get you going in the right direction.....
wait you wanted to stop, I forgot.
Also there should be three bolts on the pump end of the bracket.
They go through from the side that is up in the picture.
Old Jul 14, 2007 | 09:15 PM
1957F100's Avatar
1957F100
thanks for the picture dave. that bracket looks different than the bracket on my truck. but i got the bracket installed today and took the truck for a test drive. my brakes are good so im off to get the truck insured tomorrow morning....i cant wait to finally drive the thing.
Old Jul 14, 2007 | 09:50 PM
Dave Sponaugle
I need to take a picture of my hydraboost brake booster.
You want brakes, it will cost you a bit over 500 dollars.
But stopping power is not an issue.
Old Jul 14, 2007 | 09:55 PM
1957F100's Avatar
1957F100
what kind of brakes do you have dave?
Old Jul 14, 2007 | 11:19 PM
Dave Sponaugle
I have a hydra boost that runs off the power steering pump instead of the vacuum brake booster.
It was stock on a 96 F450 Superduty.
You need a different power steering reservoir that has two inlets and one outlet.
Then you remove the pressure line to the steering box from both the pump and the steering box.
A new pressure line goes from the pump to the hydra boost unit.
A second new line goes from the hydra boost to the steering box.
And a third new line goes from the hydra boost to the pump as a return line.
Takes about an hour to change the booster out and hook up the lines.
A trip around the block to get all the air out of the system.
Wear your seat belt, if you push the pedal like you normally do with vacuum assist you will be doing a face plant on the windshield.
I found the parts receipt the other day when I was searching for a starter receipt.
quakerj
Mar 2, 2015 07:32 AM
U-HIGH75
Aug 19, 2012 06:25 PM
grafhky52
6.7L Power Stroke Diesel
17
May 28, 2012 08:12 PM
1957F100
Jul 11, 2007 10:47 PM
bob5hotrod
Nov 5, 2005 11:46 PM
