Oil Consumption
Old Jul 22, 2007 | 12:17 AM
LxMan1's Avatar
LxMan1
Are you running 91 or better octane? 9.6 to 1 shouldn't be that bad on 87 octane. Perhaps it's running a bit lean which is causing higher cylinder temps.
Old Jul 22, 2007 | 04:33 AM
HemiEater's Avatar
HemiEater
Originally Posted by Boba Fett
I dropped by another machine shop that I though might re-curve the distributor and ask them what they thought. They do mostly racing stuff. They said that they don't re-curve them anymore and that I should upgrade to a total MSD ingition setup, pro billet and 6AL. I am currently running pertronix in the distributor and a Flamethrower coil. They said that more engines these days are being eaten up by the lousy gas and old distributors than ever before. I got 9:6 to 1 in that thing which is high.... so I probably should have used AL heads. At least I finally know what's going on with the darn thing!
Is this a race truck?
How did the Mystery oil stop the oil burning? Guess thats why they call it mystery oil A!
Never though igintion would cause an engine to burn oil this soon on a rebuild.
Never had one burn oil like yours either so I don't know..but it's not the ignition.
Old Jul 22, 2007 | 09:46 PM
Boba Fett's Avatar
Boba Fett
It is definately the ignition...... I drove it today and with the timing at 10 initial and 32 total (what the stock one had by 3000) it still has the pinging knock around 2500+ under load.
Why the mustery oil stopped the bruning of oil? It is Mystery oil you know.
Honestly I don't have much experience with the stuff, but my one friend swears by the stuff. What he knows about mechanical stuff compared to me is like a shot glass versus a fifty gallon drum.
I would guess it is a good fuel stabilizer and therefore you get a much more consistant burn with it in the gass and therefore it counteracted the desire of the gas to detonate early and rattle the rings and also gives you a better ear for the opperation of the engine.
I only run 92 or better octane gas, so I can't do better than that.
Before the smoking, right after fire over, it was running rich, and the vacum guage agreed with the carb adjustments I made to drop the initial jets from 64 to 62.
It was really after the first 500 miles this problem with the pinging started, which is because I was starting to drive it on the highway to begin fine tuning the engine.
Old Jul 22, 2007 | 09:48 PM
Boba Fett's Avatar
Boba Fett
I'm also gonna get some collectors with O2 sensor bungs on them to use a computer mixture thing to sort the miture out because right now I don't have a lot of confidence with the vaccum guage on this thing.
Old Jul 25, 2007 | 09:26 PM
Boba Fett's Avatar
Boba Fett
Leakdown test results puts the cylinders all between 15-20% leakage. The engine was built with standard gap rings. I got the bungs welded in and now I need to wire up a cigarette lighter to run the air fuel ratio meter.
This is a real PIA if you get me. I'll let everybod know how it turns out.
Thanks for all the help!
Old Jul 26, 2007 | 04:32 AM
HemiEater's Avatar
HemiEater
so what did the machine shop gap the top ring at?
Old Jul 26, 2007 | 11:53 AM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Remember what I posted earlier:
You are probably losing 2 to 3 mpg by not having a good performing vacuum advance.
And you need to be able to run more than 10 degrees initial in order to have real good acceleration.
Also suggest running at least 89 octane.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Aug 6, 2007 | 10:27 PM
Boba Fett's Avatar
Boba Fett
Big news! Job done!
I got the MSD stuff on there and the bungs in the exhaust......
I will say this about those guys at Holley: The had the carb setup perfectly right out of the box, at least according to the O2 sensors and FAST.
I got the timing set at 14 initial, and used the third slowest advance curve and the spark knocking is gone and so is the smoking.
Old Aug 7, 2007 | 08:31 AM
Kemicalburns's Avatar
Kemicalburns
sweet, good to hear.
