Sponsored by: Real Truck
NO Crank
Old Jul 10, 2007 | 12:34 PM
dieseloholic's Avatar
dieseloholic
NO Crank
Need some help guys. I have an 99.5 F350 w/7.3. I've had this problem three times now. The truck runs perfect, I get to where I'm going, shut it off and then it won't restart. The cluster comes up, all the relays and fuel pump cycle, but when I try to start it... nothing. No clicking or anything. The past two times I let the truck set after trying 50+ times and several hours later when I tried it started on the first attempt. This time I let it set like before, but it still won't crank. I've checked the batteries and all connections and everything seems to be fine. I pulled the nuetral safety switch connector off; no signs of corrosion or anything else. I tried putting it in nuetral, no difference. I don't know how to bypass the ingnition switch to rule it out. Any advice would be great. Thanks
Old Jul 10, 2007 | 01:21 PM
WhëëlMå1's Avatar
WhëëlMå1
I am not sure how that particular fuel system is run, but could vapor lock be a cause?
Old Jul 10, 2007 | 01:25 PM
redford's Avatar
redford
FTE Leadership Emeritus
Never heard of vaporlock on a diesel.
When you say "no crank" you mean the engine doesn't
turn over when you turn the key?
Based on the fact that it does it when warm (so far anyway) my guess would be your starter is going south on you.
Old Jul 10, 2007 | 01:26 PM
WhëëlMå1's Avatar
WhëëlMå1
Yeah, I wasn't sure. I am a gasser, but just trying to think up any plausible reason.
Old Jul 10, 2007 | 01:30 PM
dieseloholic
yeah, it doesn't crank over. The starter doesn't even click.
Old Jul 10, 2007 | 01:33 PM
redford's Avatar
redford
I'm not familiar with the starting circuit on the 7.3 PSD, but I suppose it could also be the solenoid.
Old Jul 10, 2007 | 02:52 PM
kevman41635's Avatar
kevman41635
I have seen a lot of times on old ford 5.0's that it is the starter. They sometimes will not work when they get hot.
Kevman
Old Jul 10, 2007 | 02:57 PM
God_hammy's Avatar
God_hammy
here is the diagram, hope it helps.
Old Jul 13, 2007 | 09:24 AM
God_hammy's Avatar
God_hammy
[img=http://img66.imageshack.us/img66/6556/exo02002ew6.th.gif]
here is that again.. hopefully a more reliable host
GT V10
Nov 6, 2009 01:09 PM
Gubas
Jun 2, 2009 07:41 PM
dieseloholic
Jul 13, 2007 10:20 AM
badexpresso
Feb 13, 2004 04:43 AM
