I am looking to buy a 7.3 PSD, crew cab, long box. Undecided on dually or singles. Year 2000-2002. That said, I test drove a 2001 and I thought the steering had excessive slop in it. You could turn the wheel a couple inches without getting any steering input. A little scarey on one off-ramp when it didn't turn right away. I am used to my Ranger which is nice and tight, responds to slight movements on the wheel. My wife's Explorer is similar, though not quite as tight. This is the first 350 that I have driven. Are these things made that way (can't imagine) or is there something wrong? Ball joints or tie rods? I searched around a bit and found some threads about fixing sloppy steering, but what is "normal"?
I think its normal for these trucks to be a little loose, but what your describing sounds pretty excessive. Did you not get any response at all or it was just very minimal? These larger trucks are longer to turn and dont turn as sharply as a small truck/suv, nature of the beast i think.
When I was looking for my truck I did test drive one such, the steering had zero effect for 25 to 30 degree turn on either direction and the seller insisted that it was normal for lifted trucks! I thanked him for that scary interpretation and moved on…like most suggested above, you should look around some more… ALL THE BEST!
Not an expert on that, But I do not find any obvious difference between my mustang and my F 350 steering responses. Granted my truck feels like a truck, little effort to turn tightly...but would turn on dime. Also, the turning radius is high hence some wide angle turns there, unlike cars with smaller wheels…
Mine steers terribly. Still replacing components to try to get it right (dampener, tie rods, alignment, tires, etc....). Eventually, I hope it will steer better, but, dare I say, will likely never be as tight as an IFS chevy. But I am good at grenading CV joints!
Depending in the mileage, it is probably a tired steering gearbox. That is not normal, and a new one sould be fairly responsive. The way to tell is have a friend turn the wheel and look through the fenderwell to the box. look at the input shaft and the pitman arm simultaneously. If there is a lag, the wear is in the box, if there is no lag, then it is somewhere else in the steering linkage, and there will most likely be clunks and tire wear to accompany things. In my opinion, Ford's gearboxes wear out a little to quickly compared to other brands, but if that is the biggest problem, then it is a minor nuisance. Try and use it as a haggle point, and don't let him tell you it is normal.
Thanks everyone, this is what I suspected. I'm going to look at another tomorrow. I can go back and haggle with them if I choose. After driving the diesel I'm hooked.
The box might be the problem but SDs are notorious for the passenger side of the drag link wearing out, especially if you dont have a stabilizer. If you replaced that and the ball joints, then tightened the box, it would steer like a honda civic only alot bigger.
Replaced the steering stabilizer on mine along with wheel balancing and alignment.....
still a little play but not too bad and the vibration at 70 to 75 is gone.
Welcome to FTE, Camperboy!
You didn't ask, but based on your handle I'm assuming you are wanting to carry a slide-in truck camper? If so, do yourself a favor and get the dually. A single rear wheel Superduty is overloaded per Ford's GVWR limits with any larger camper out there once you add all your normal gear. And if you don't care about GVWR like many camper owners, you should definitely care about the tire ratings and those are easy to exceed also. My claimed 2900 lbs dry weight camper will even overload my dually if I'm loaded up for a long trip, but I'm along way from exceeding the tire or axle ratings.
When you're driving on the highway, you should be able to move the steering wheel only slightly one way or the other and it should start moving into the next lane. The spool valve springs should be strong enough that just a slight movement of the wheel will start to move the front tires one way or the other.
If you have a dead-spot of more than one inch at the edge of the steering wheel, that's way too much.
