big block vs. small block
Old Apr 13, 2002 | 01:42 AM
lvstang's Avatar
lvstang
[updated:LAST EDITED ON 13-Apr-02 AT 02:43 AM (EST)]> The outside dimensions of the "C" and "M" blocks, are
>larger than the 302/351. The 302 Boss, which had "cleveland"
>heads, was considerably smaller than the "cleveland" block
>(width, not deck height).
> I believe they refer to these blocks as "mid-blocks",
>because the outside dimensions are quite larger than
>"windsors", not just considering the deck height, but the
>width of the blocks, which also indicates a different degree
>of V angle.
I don't mean to argue with you but concerning the C block your info is skewed. They are ALL 90* blocks and the C block is actually a tad narrower than a 351W. Of course the 302 is not as wide as either. I will agree the M/400 block is wider but at the sake of being redundant all blocks share the same bore spacing, bore and all heads are interchangeable.(with water jacket mods)
Obviously the "C" style head makes the total package wider. But we are talking blocks.
Just in case it hasn't been mentioned page 113 and 114 of the 2002 FORD RACING PARTS catalog lists the small blocks as 289/302/351W/351C/351M/400
Old Apr 28, 2002 | 11:09 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You guys are neglecting that the smallest FE engine is the 332, not the 352.
Josh
Old Apr 28, 2002 | 11:59 PM
canzus's Avatar
canzus
>332, not the 352.
Josh,
If you go back to the beginning of the thread, you'll see that Imentioned the 332, as a "big block". The trouble lies in how
you perceive each engine...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Old Apr 29, 2002 | 01:13 AM
ty's Avatar
ty
Ive always under stood that Chevys were designated small block and big block and the Fords went by engine family and werent designated small or big block.
Old Apr 30, 2002 | 11:28 PM
Bullitt390's Avatar
Bullitt390
It was never referred to by name or displacement. All that was discussed in the latter part was the 352, which as I stated is not the smallest FE engine and therefore, should not even be considered in the argument.
The 332 WAS a big block at its time. The 60s era brought the rapid growth displacements, just look at the short time it took the FE to go from 332 to 427, basically 5 years.
Josh
Old May 1, 2002 | 12:16 PM
airharley's Avatar
airharley
Old Mar 8, 2022 | 09:02 AM
Falcon67's Avatar
Falcon67
Big and small block are Chevy terms. So there.
Say "335 Series" "385 Series" "Lima" "Windsor" "Cleveland" "FE" "Y Block" Don't say "400 Cleveland" because there's only one. LOL, yes, there actually exists a bit of Ford literature that actually says "Cleveland 400"
jessfactor
General Automotive Discussion
62
Apr 26, 2016 06:57 AM
TheDawnof68
23
Sep 29, 2014 07:07 PM
old farmer
Oct 8, 2008 12:15 AM
89ford73
Sep 15, 2007 04:02 PM
77fordguy
17
Aug 3, 2005 11:04 PM
