visous fan
Old Jul 10, 2007 | 09:14 AM
partsman01's Avatar
partsman01
visous fan
Well after reading some here about the clutch fans, I tried spinning mine when the truck was warm, my fan only moved about a 1/4 turn when I tried spinning it.
So I gather my fan may be alright, will wait till it cools here at work and try it cold.
Old Jul 10, 2007 | 10:31 AM
lsrx101's Avatar
lsrx101
Not necessarily. That test doesn't tell you how much it slips when it's pulling air at idle. It can still be weak.There's really no good way to test a fan clutch.
What year is your truck? If it's about 8 years old or more (or more than ~75K miles) just replace the clutch. They're a maintenence item that is most often overlooked until it fails completely.
One of the first signs of a weak fan clutch is reduced AC cooling at idle and low speeds.
Old Jul 10, 2007 | 11:18 AM
fasthauler's Avatar
fasthauler
The procedure we used, back when I was doing it, to test the fan clutch was to use cardboard to block the radiator. The cardboard had a hole cut in the center of it the same size as the hub unit on the clutch. This was about six inches. We removed the radiator cap and put a candy thermometer in it to measure the temperature. You place the cardboard in front of the radiator with the hole centered over the fan hub. We would run the engine until the fan clutch kicked in. You use the candy thermometer to see where the fan clutch kicked in at.
The hole provided the heat directly to the fan clutch giving a more accurate reading of when the clutch kicks in.
partsman01's Avatar
partsman01
It is a 1977 F-250 400/6.6litre C6 auto.
Some of the topics to do with cooling made me curious if I could tell if it works.
I think up here the clutch goes for 71.00 CDN for mine, which I believe is a 2797 from Haynes.
Old Jul 10, 2007 | 11:53 AM
fasthauler's Avatar
fasthauler
I think you mean Hayden, if not I didn't know Haynes made clutches Also unless you are doing a lot of heavy duty stuff with that truck I would just get the regular duty clutch instead of the heavy duty. They seem to be more reliable. (and cheaper)
Old Jul 11, 2007 | 01:24 AM
partsman01's Avatar
partsman01
Yes, I meant hayden.
Well with fan cold it rotated just as far as when hot, which is one quarter of a turn when spun.
Old Jul 11, 2007 | 09:59 PM
fasthauler's Avatar
fasthauler
The only way you are really going to test it properly is with the cardboard as I described above. You will hear the roar when the thing locks up. If you get that engine over 220 and that fan is not roaring then the clutch is no good.
Old Jul 11, 2007 | 11:53 PM
partsman01's Avatar
partsman01
Okay, thanks.
Old Jul 12, 2007 | 12:45 AM
lsrx101's Avatar
lsrx101
That's actually not a good test either. It tells you nothing about how much RPM differential there is at idle when it's really needed for AC operation. That test only tells you if it is actually capale of "locking up" under full heat load.
In all fairness, that IS a good test if you have an engine that's running too warm at low speeds, especially on a vehicle that doesn't have AC.
The engine cooling system is very forgiving of a weak fan clutch. On a truck with no AC and a weak fan clutch, you won't notice it until the clutch is almost dead at idle. On a vehicle with AC, the first indication of a failing fan clutch is poor AC cooling at idle or low speed.
Old Jul 14, 2007 | 12:42 AM
fasthauler's Avatar
fasthauler
You need to tell the Ford people that then. That is the procedure they show in their service manual as the proper procedure to test the fan clutch. I can send you an excerpt from the manual if you would like to see it.
Old Jul 14, 2007 | 06:55 AM
2000Ford2000's Avatar
2000Ford2000
That's the reason that you can't get good Ford service at a dealer (Or any dealer for that matter). Independents know how to do these things because they've actually learned it rather than read it. LSRX is right about the clutch check as I know from personal experience. The test is a good one but it's not 100%.
I work in an electronic shop and what I've done is put reflective tape on one blade and checked the RPM with a reflected light tachometer. Compare that to the engine RPM and you can get a real good check, but most people don't have access to that type of tach.
Old Jul 14, 2007 | 10:10 AM
lsrx101's Avatar
lsrx101
Originally Posted by 2000Ford2000
Content trimmed
That method actually works pretty well. It will tell you the fan speed at all RPM and the airflow can be judged from that pretty accurately. Like you said, though, most folks don't have a strobe tach. Being a wear item, I find it easier to replace a suspect clutch.
Old Jul 14, 2007 | 12:05 PM
fasthauler's Avatar
fasthauler
It would be a heck of a lot cheaper to just replace it as well, but what happens if the new unit is bad also? (This does happen) At least testing it with the cardboard does give you and idea if it is functional at all. Most of the guys on here are diyer's and do not have access to sophisted equipment. It would be cheaper for them to take it to a garage and have it done than buy that kind of equipemnt, but they wouldn't be here looking for advice if they were willing to do that. The section I posted was only part of the test procedure in the Ford manual. It is two pages. I just paraphrased what I thought was the most expedient thing to do.
Old Jul 14, 2007 | 04:35 PM
lsrx101's Avatar
lsrx101
I wasn't disputing what you wrote. That test has it's place. (I did say that it will show if the clutch is capable of locking up). I was just pointing out that particular test isn't really accurate at idle speeds. That's why I keep saying that, for all practical purposes, there's no good way to test a fan clutch. You use symptoms and some deductive reasoning to determine if it is weak. If it's more that 7-8 years old or more than ~70K miles, replace it.
As far as a new clutch being bad out of the box, yes it can happen. It casn happen with any part. That's why it's important to use quality parts with a good track record of quality control. The likelihood of an NIB failure will be statistically less.
Old Jul 15, 2007 | 01:24 AM
bustech81's Avatar
bustech81
Being from a shop that has delt with this problem, what i do is just replace a suspected weak clutch. if a little water on the condenser drops head pressure like a rock, more than 60 pounds or so, replace the damn clutch. my shop rate is $100 per hour for refridgeration diagnostics. Clutch is approx $80 and $50 to r&r. seems like a no brainer to me.
torpedo51
Oct 20, 2021 07:19 AM
Carloespo
Nov 4, 2016 07:02 AM
Weltonsam
Oct 10, 2016 05:49 PM
GuitarJesus
Oct 5, 2016 09:00 PM
BigMattXXL
Sep 3, 2003 07:10 AM
