Sponsored by: Real Truck
Gooseneck ball placement ?
Old Jul 9, 2007 | 07:44 PM
broncoman604's Avatar
broncoman604
OK, I just got my B&W turnover model 1108R, I have a 03 CC short bed 4X4, and the instructions with the kit have a ball placement for both long and short bed trucks of 47" from the tail gate, I had been looking at these hitches and thought I would get a model 1105R which has two different options for placement one being 46" and one 49" (long bed only). My question is will I notice the 1" shorter distance between the cab and trailer or not? I'm mainly going to be pulling a standard Goose-neck flat bed but may go with an enclosed or even have to pull a large enclosed horse trailer with the living quarters in front. The best I can tell is that if I were to slide the side plates and rails back 1" I could just drill new holes in the side plates, not sure if it would be worth it or not.
Old Jul 9, 2007 | 08:21 PM
F350-6's Avatar
F350-6
I think the different options on the long bed model install have to do with a rear sway bar. I have a B&W in my long bed that the dealer installed in the wrong spot and if the ball is upside down it hits the sway bar over large bumps and dips. I don't know which model B&W I have, but I can tell you from the amount of metal rubbed off each piece that the sway bar is tougher than the ball.
Old Jul 9, 2007 | 09:31 PM
broncoman604
I'll definitely look at clearance issues and take many measurements before drilling.
Old Jul 9, 2007 | 09:38 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
if you will be pulling an enclosed type gooseneck you need it to be as far away from the cab as you can get it
Old Jul 9, 2007 | 10:03 PM
broncoman604
Most of the time I won't be but i may every now and then, I just don't want to get the ball location to far back. I've always heard no less than 2" in front of the rear axle center line. The hitch if installed in the factory holes would be 3-3/4 in front of the center line so I could possibly move it back a 1-3/4" if the 2" rule is good.
Old Jul 9, 2007 | 11:05 PM
KubotaOrange76
you should be fine with the 3 3/4"
lhansman
6.7L Power Stroke Diesel
Feb 11, 2015 11:47 PM
90pioneer
29
Oct 28, 2014 06:18 AM
keld
Nov 4, 2013 11:00 AM
Cowboy65
All Things Towing
Sep 4, 2013 07:42 AM
dt444e
All Things Towing
Sep 23, 2007 01:31 PM
