03 Explorer XLT Trans Leak
I had a huge problem with my old '95 tranny and decided to try and take better care of my 03.
The owners manual says that the semi-synthetic fluid in the 03 tranny is good for 100,000 miles (or maybe even 150,000, I'm not sure). I decided to have it flushed at 40,000.
I had the dealer perform it's fluid exchange service (at 40,000) I was never sure if they changed the filter or not (I was not even sure if it had a filter, maybe just a screen).
I had the tranny serviced again at 77,000 miles. Up until then I had no problem with the tranny at all. this time I looked at the bill and noticed that I was charged $130 for the fluid exchange and seperately listed about $20 for 6 quarts of trasnsmission fluid.
I asked about it and was told that the $130 included the fluid pump out (and replacement) and the seperate 6 quarts was for what was in the pan. I took this to mean that the pan was dropped AFTER the fluid pump out/replacement (which is what I wanted.
Anyway, I had the 77,000 mile work done on 6/21/07. sometime in the middle of July, I noticed a little puddle (maybe two capfuls) of fresh tranny fluid under my car. I was at a gas station pump and I wasn't even sure it was from my car. If it was, I thought that it might be a little that was trapped on the outside of the tranny after the service.
By two weeks later, I was sure my car was leaking tranny fluid. The tranny still felt fine, but there was fluid spotting my driveway every night.
I brought it back to the dealer and was told that my Torque Converter was leaking and my tranny was making noise. When I showed the leak to the dealer, I also noticed that the fluid seemed a little burnt.
The dealer is pulling my Torque converter and tranny and tearing them down. My bet is that there going to end up replacing a seal in the torque converter and installing a new transmission. All of this just 6 weeks after there routine tranny service. Pretty coincindental, HUH.
Anyway, I'm glad I got the 100,000 mile ESP ($100 deduct).
So far I've had:
- My rear axle rebuilt (at 77,000). Not a complete rebuild, but they have a kit for replacing clutch componants
- My rear hub Bearings changed
- My A/C condenser coil changed
- Now my tranny and torque Conv pulled apart
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE><!-- / message --><!-- no sigs except when logged in --><!-- sig -->__________________
