Okay i guess i can be first.....and maybe not correct but.......
Don't you just have to change the springs around and you could use what ever rear axle you choose. I would use the 9 inch.
The reason I drive Superduties are because they are work trucks. The 700km to a tank of fuel with the diesel is nice too. I don't know to many people that want to restore a truck and take it out in the bush and sink it to the frame.
i was thinking of trying to find a conversion kit for it, or find a whole axle assembly at the wreckers. the truck i had in mind is only a half ton 2wd, the conversion would be mostly for looks.
