Click!!
Old Aug 25, 2007 | 01:24 PM
  #31
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Batteries check out perfect. Right now I just need to know where the main ground strap is. It must be dirty, or loose.
Old Aug 26, 2007 | 12:21 PM
  #32
pngrantham's Avatar
pngrantham
Solenoid
Why not the Solenoid. Sounds like the most logical to me.
Disconnect the Batteries. Remove 2x 13mm Bolts securing the Starter to the Block, Replace the Solenoid. No more Problems. I'm surprised, after 30 replies, someone besides me hasn't mentioned it. It's about a $15 Repair for the part.
Old Aug 26, 2007 | 12:51 PM
  #33
Markadeck's Avatar
Markadeck
I'll try that, but where do I find just the solenoid? The only place I've checked told me it was not a stand alone part. But my first thought when I saw the arc from positive to negative on the solenoid was that something internal had gone wrong with the solenoid.
Old Aug 27, 2007 | 08:47 AM
  #34
pngrantham's Avatar
pngrantham
Try this # for a Solenoid, 800-327-7792.
When replacing, Do Not OverTorque! They are easy to break.
Old Aug 27, 2007 | 09:01 AM
  #35
Markadeck's Avatar
Markadeck
I've decided to bite the bullet and replace the damn starter. I need the truck ASAP and already have the old one out. This is my usual method of fixing things. Stand back and toss money at it. Thanx for the help.
Old Aug 27, 2007 | 10:21 AM
  #36
farmdad's Avatar
farmdad
If the new starter doesn't fix the problem, you might want to check the cable ends or the cables themselves. If you have had a bad connection for a while, you might have "burned" the connector or the cable. I had that happen with a ground cable on a tractor. Cable looked fine but it wouldn't conduct any juice. Replaced it, after replacing 2 batteries and the starter, and everything was great. Don't scrimp on the size of the cable. The bigger the better, up to a point.
Old Aug 27, 2007 | 11:56 AM
  #37
Markadeck's Avatar
Markadeck
The new starter fixed the problem. What ****'s me off is that I bought it in Fairbanks last year, came with a lifetime warranty, but I have to return it to one of their stores. Here I am in North Carolina and their nearest store is in California. Lesson learned here is, buy from an auto parts store that has branches everywhere.
Old Aug 27, 2007 | 12:30 PM
  #38
farmdad's Avatar
farmdad
Glad to here that you got it fixed. That is always a good feeling. I agree with you about buying where you can get customer service. It may cost a little more at first but at least you have some place to go if something goes wrong with the part.
Old Aug 27, 2007 | 11:13 PM
  #39
kawika's Avatar
kawika
Just keep that part and the next time your in an area where the store is at, return it.... then you'll have a spare.
Dave
Derekholt
Feb 22, 2015 03:01 AM
Jrakar
1997 - 2003 F150
Feb 16, 2011 03:49 PM
varunner696
Electrical Systems/Wiring
Jul 12, 2009 06:30 PM
exiled
Jan 2, 2008 04:22 PM
79beater
Jan 25, 2007 10:11 PM
