Sponsored by: Auxito
1998 F150 just clicks when started
Old Feb 15, 2011 | 06:43 AM
Jrakar's Avatar
Jrakar
Got a 1998 F150 with 117k on it. Went to start it last night and all it did was one click. Tried it again and all I got was a click. Tried several times and that was it just a click. Lights work, radio comes on, ect. Tried it again and it fired up. Popped the hood looked at the connections on the battery and they look great. No white stuff and they were tight. The terminals still had the red stuff on them. I took a volt meter and it read 12.5 volts. Pulled the cover off of the selonid and they connections look good and tight also. Looking for suggestions.
Old Feb 15, 2011 | 08:26 AM
phil6608's Avatar
phil6608
Sounds like the starter is on it's way out.
How old is the battery?
Old Feb 15, 2011 | 11:02 AM
Ron W.'s Avatar
Ron W.
Start at the battery and follow the positive cable, I believe your truck has a starter relay on the firewall.
Old Feb 15, 2011 | 12:05 PM
Jrakar's Avatar
Jrakar
Yes it does and I have checked all of the connections on it. They are all clean and tight.
Old Feb 15, 2011 | 12:25 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
take a small hammer and tap the starter all over, and try to start it again. Sounds like its the solenoid on the starter to me.
sometimes a small bump can get them going for temporary use.
Old Feb 16, 2011 | 03:02 PM
sigsr01's Avatar
sigsr01
Might as well change em rather then tapping it, while it still work drive to autoparts and buy starter. If its your only ride, it will be bad situation once the starter goes out.
But then again it seems like is just a battery needing to be replace.
Old Feb 16, 2011 | 03:49 PM
BURNSTOUGHFORD
hence the reason why the tap test will let you know if its the starter..........
Chad Pinkston
Jan 29, 2018 09:06 PM
Cothfotmeoo
Sep 3, 2016 11:10 PM
bigdan1979f-250
Jun 5, 2016 09:08 PM
Ford Goblin
25
Jul 21, 2015 11:44 PM
NAMDROF
Oct 23, 2014 10:35 AM
