Computer Chips & Tuners
chip for speed density possible?
Old Jul 8, 2007 | 12:06 AM
390Highboy's Avatar
390Highboy
I have a 93 f150 with a 5.0 and a 5 speed. Is it possible to find a chip or tuner that will work with speed density with no ill effects? I noticed that summit racing has several listed for the truck, but they do not say whether they are speed density compatible.
Old Jul 8, 2007 | 06:59 AM
jdadamsjr's Avatar
jdadamsjr
"Speed density" ?
guess I gotta get out more - that's a new one on me
is that an aftermarket company or ?
can u 'splain it to me ?
Old Jul 8, 2007 | 02:24 PM
blucollar4xford's Avatar
blucollar4xford
Speed density is actually a Non Mass Air Flow engine. But i coulda swore that after 88 all the 5.0's were mass air flow engines, i have an 87 i converted to mass air flow, but i had bought a thing called Venom 400 PCM for it and it will only come on when you are giving it moderate to full throttle. I noticed a pretty good difference with it on. The only thing i had to do was hook one wire to one of the wires on the TPS sensor and one to my Aircharge sensor wire and then power and ground. It also said it would work with mass air flow engines as well. it'll cost ya around 350 bucks for it, but i thought it made my stang run pretty good.
blucollar4xford's bro-in-law
Old Jul 8, 2007 | 09:58 PM
390Highboy's Avatar
390Highboy
My truck does not have mass air and it is pretty much stock. I don't want to dump a ton of money into it, but I wouldn't mind spending $350 on something that would make it go a little better.
Old Jul 9, 2007 | 11:11 AM
FTE Ken's Avatar
FTE Ken
Superchips, SCT and I believe Jet all have applications for it. Its established, older technology so you should have no problems with it.
Old Jul 9, 2007 | 07:59 PM
390Highboy's Avatar
390Highboy
Ok, thanks for the info.
Old Jul 9, 2007 | 08:41 PM
FTE Ken's Avatar
FTE Ken
Also, if you're looking for custom tuning, I believer Troyer Performance can handle this with custom SCT tuning. He's a sponsor here, let him know you're from Ford-Trucks.com and he cuts you a deal at his group buy price. I think that's still current.
Old Jul 17, 2007 | 09:06 PM
shuttlevalve's Avatar
shuttlevalve
i put a diablo chip with the 3 program option. Works good, but it was custom done on a chasis dyno with a wide band O2 pluged into it.
r6bikerdave
Mar 23, 2017 04:21 PM
RAY1986F150
26
Feb 4, 2013 01:15 PM
Mike662
Feb 2, 2004 08:55 AM
Kemicalburns
Mar 31, 2003 09:27 PM
