congrats Steve! nice numbers! just shy of 900 ft lbs. that is very nice
Thanks Tim! Numbers are gettin there. I would love to hit 900lb ft. runnin straight #2 but I dont wanna run bigger sticks til i get an intercooler and headstuds goin. i think after that tho Im gonna run stage 2's on a SD hpop. Luke did it so I think I'll be good to go. So until then its NOS baby! lol
By the way, its your turn for the NOS brother. Rubber and I got it done, your next on the list....
I need more fuel!!!! my goodness, lol. Did you see a drop in EGT's? I saw about a 150* temp drop on the dyno. I havent used this stuff on the street yet. big fine if you get caught with the bottle open. I think i'll try it on the back roads. Im afraid to run the 200hp shot through the motor. I dont wanna lift the heads. Did you see more boost numbers when you used your shot? I saw maybe a pound if that increase. kinda dissappointed, i was hoping for 5-7lbs in boost gain. oh well the power is there.
Thanks again Arch Bishop!
Cowboy Steve
I only saw 1-2 psi in boost, and to tell you the truth, when I'm spraying it, I'm usually street racing and don't stop to look until I'm passed 1400 degrees so I couldn't tell you on the EGT's. But I would really advise against the 200 shot. Denis a TS and I talked alot during my setup. He was telling me that's usually where they saw their major failures. But who knows. Later.
i was picking up 100rwhp with a single stage and a .073 jet. Boost only increased a couple psi. This was with huge stage 3 injectors, i doubt you'll gain anything by going to a 200shot with stage 2's.
i thought you had 2's, how are you making that much with stage 1's? They do not have enough fuel for those #'s period, sounds like youve set of 2's. Stage 2's would be maxed out with nitrous and the numbers your putting down. I wouldnt push too much more hp than that on a stock engine, you will break something.
Holy crap you get a ticket if you have a NO2 bottle turned on?? Gesh that's a bs law right there. Just get you one of those electric valves. Problem solved.
Wow Luke, After reading your post i called up Dusty at BDP and he verified your input. My oreder through them was stage 2's. For some odd reason I thought I had stage 1's. Good man Luke, Kudos to you
Haha yeah no joke. I would've looked like a dumb fool to after I called up BDP and b1tched 'em out cause i didnt see a jump in hp, lol. Luke's a life saver!
Cowboy Steve
I knew that either the dyno was way wack or some how you got different injectors than stage 1's lol! Your making some hellacious numbers for stage 2's
