Steering Column Bearings
Old Jul 7, 2007 | 07:19 PM
netscaner's Avatar
netscaner
I took tore off my steering wheel a short while ago, and found that the upper bearing in my tilt steering column is trashed. It appears to have a spring load held on by a snap ring, that loads a conical upper and lower bearing.
I did some searches here and in one of the threads someone listed it available at both Napa and Ford. It was too late to run up to my Ford dealer, and Napa says they don't have one.
In another thread someone mentioned a kit containing the bearing, the spring, and some sleve or thrust washer.
Does anyone have any knowledge of these parts and a place to get them ?
Does anyone have a diagram of the tilt assembly ?
Old Jul 8, 2007 | 11:30 AM
netscaner's Avatar
netscaner
Well, I guess it's wait till Monday and grab them from a local Ford or Mercury dealer.
Old Jul 8, 2007 | 07:56 PM
SilverSport's Avatar
SilverSport
I was here earlier and posted this link for someone else .... Bronco Boy has a diagram in is actuator replacement thread here. http://www.fullsizebronco.com/forum/...ad.php?t=70454
Hope this helps.
Old Jul 8, 2007 | 10:44 PM
netscaner's Avatar
netscaner
Thanks SilverSport, that's a really good thread.
But It's for a 1985, mines a 1994 which is very different.
The column bearings are ball rather than needle and have a spring loaded cone that keeps them at zero play, until of course they disintegrate if they are never lubed, LOL.
Old Jul 9, 2007 | 11:11 AM
netscaner's Avatar
netscaner
Well, my Ford dealer didn't have my bearing in stock, but a dealership also owned by them had two, and was only about 5 miles away.
Good thing I had the numbers that was mentioned in a thread that I found in a search here, because Ford has the upper and lower bearings mixed up in their computer.
The upper (smaller) (closest to steering wheel) is # F4DZ-3517-A.
She really returns to center much better now, And no crinkling noises.
Old Jul 9, 2007 | 11:39 PM
SilverSport
Glad you got if fixed .... sorry .... forgot they changed the columns in 92 as well as the grille.
Fordication
Jan 5, 2017 07:25 PM
zdumpor
1978 - 1996 Big Bronco
Aug 18, 2016 08:58 AM
mattt181
Feb 28, 2016 04:14 PM
73FOMO
Jun 20, 2007 10:25 AM
mechanicsburg
Dec 2, 2004 05:40 AM
